just go my mk2 back after a while, the fans still work, and aircon, but the heater wont blow hot air, kind of frustrating with melbourne weather being inconsistant
, any ideas??
heater wont blow hot air!!
Get the car up to operating temperature, open the bonnet and feel the two rubber pipes that go from the motor to the firewall (and on the the heater). The pipes are about 2cm in diameter. Both of them should be warm/hot. If not, the water isn't going through your heater and you won't get any heat out of it.
If only one is warm you've got a blockage somewhere that isn't letting hot water flow through the heater and out via the 2nd rubber pipe.
Paul1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
Are you losing any coolant at all? Maybe the heater flap is broken, is it still blowing cold air when you switch it to hot or does it change a little? I think the heater flap in the golf is vacuum fed so possible a leak or a broken flap...Originally posted by Spyda View PostWe checked it and both heater core pipes get hot but still not hot air.----[ Finished the search for a mk2 GTI]----
1990 Golf Mk2 GTI
276* cam
2 1/4 in straight through exhaust
H&R springs on KYB shocks
Yeah i know we are having a few probs with them on the falcons so most likely to be the same problem here, gonna be a dash out job to get to itOriginally posted by Bboy_Sparx View PostThe flap is a common problem from what I hear. This has happened to mine ARGH
1990 Golf Mk2 GTI
276* cam
i rekon you my be right, when the car idles in traffic and warms up to half, the heater blows hot air, when i start to drive the temp gauge cools all the way down to the bottom, and the heater goes cold.Originally posted by Bboy_Sparx View PostThermostat85' MkII 1.8 K-jet(small Bumpers) SLAMMEDDD!! ( sold
91' MkII GTI sold!
Hello,
My Mk2 was exactly the same.
New heater core - no change
New Thermostat - no change (but temp guage now steady)
Replaced hot / cold air vent flap material - no change
Rip out the Valve added for Mk2 heater recall - replace with copper plumbing pipe and it's now too hot.
I can see the coolant system "residue" that has blocked and seized it up.
Just need Air con regas for summer now
