hi
i have done the cable shifter there is not much work involved all you need to do is remove the mk2 one then get a mk3 or a corrado shifter, then take the shifter you will need to line it up from underneath and drill new holes then it is just the case of bolting it up.
the parts you will require
corrado or passat pedal box
subframe from vr6
cross member from passat or corrado
corrado vr6 radiator
anything else you need to know just ask
len
subframe from vr6
len
