View Post
HELP: Leaning out??!?!
Originally posted by golfworx View PostYou've lost me fella's sorry.
If you've got a manual, read the section about removing & refitting the dizzy & read it carefully TWICE! Then follow the instruction's to the letter.VW: it aint just a car, its a way of life
Originally posted by Peter Jones View PostNah, this is way more fun!
PeteVW: it aint just a car, its a way of life
It still puzzles me why the dizzy was so far out of whack. Re do it tonight, I'll bring mine over if you need to see how the leads plug back in or something?
EDIT:
We known the flywheel and piston 1 are "matched" ie, TDC on cyl 1 corrosponds to the mark on the fly wheel (we've check through the spark plug hole)
Is it possible that the top end (cam, valves) aren't "in time" with the bottom end? as if perhaps Josh missed a tooth when refitting the timing belt and the bottom end, is out of sync with the top end?
What about the intermediate shaft? If that's out of whack, could that explain why the dizzy was so out of whack?Last edited by Jarred; 24-07-2008, 10:05 AM.
Originally posted by Jarred View PostIs it possible that the top end (cam, valves) aren't "in time" with the bottom end? as if perhaps Josh missed a tooth when refitting the timing belt and the bottom end, is out of sync with the top end?
The top is probably a tooth out. Check the bottom and top timing marks. Then when they are right, take the dissy cap off and make sure the arm is pointing at the corner of the block.
Then all you have to do is put the leads on right. 1 4 3 2.
Good Luck.sigpic Camden GTI Performance. VW / AUDI Specialists
Originally posted by gtimk5 View PostUmmm, Loon, 1342 thanks!!!
DOH. My typo. sorry Josh that could have stitched you upsigpic Camden GTI Performance. VW / AUDI Specialists
Originally posted by gldgti View Posttrying to imagine what 1432 would sound like....... dug dug............dug dug.........haha
Oh Hang onsigpic Camden GTI Performance. VW / AUDI Specialists
You guys are missing one prominent point here... Josh had the same problem with this carby on a DIFFERENT ENGINE.
Originally posted by Preen59 View PostYou guys are missing one prominent point here... Josh had the same problem with this carby on a DIFFERENT ENGINE.
this carb had the exact same problem as im having now on Jarreds engine and that fuel pump is working perfectly!
i get the carby rebuild kit tommorowso ill let you all know what size the jets are and ill take some general photos of the condition
and while im at it ill check all the TDC markings and make sure they are juuusssttt right! and put the dizzy in properly.VW: it aint just a car, its a way of life
ok updates!
ripped it apart and heres how it stands:
Venturi's: 33
Pump Jet: 40
Main Jet: 135
Float Weight: 26
i have a feeling the mains are too small??
also putting in the new needle and seat i think the float level is to low. hmm how can i measure this accurately before adjusting anything?VW: it aint just a car, its a way of life
