It's a 40 DCOE right? i'm guessing 32 or 34mm chokes. Most likely 32.
yeh well car wont even start now carb will be coming off Friday, its too cold now!
VW: it aint just a car, its a way of life There are few things more satisfying in life than finding a solution to a problem and implementing it
We did line up, from cyc 1 was lined up with lead 1 at the marking on the dizzy, while the engine was at TDC (we check by removing the spark plug trick, it is lined up with the flywheel TDC too)
Wouldn't it fire on atleast on cycl 1? and not the rest if we mixed it up?
EDIT:
We havn't looked at cam pully markings yet. is it possible the intermediate shaft is out of whack from when josh changed the timing belt, hence why the dist was so far out?
EDIT:
Ummmm I'm not quite understanding you at this point.
This is a 4 stroke motor, the pistons go up and down twice for every rotation of the distributor. To make sure you're on the firing stroke look for the dot on the motor side of the camshaft pulley to line up with the rocker cover flange at the front of the motor.
how about this....
a slab of the persons favourite bevvy to whoever helps me get this dam car sorted!!!
Don't just go off the flywheel mark. Also use the cam pulley marking's. That's what there there for.
If it's 180 out, it won't run at all & spit fuel out the carb, most likely with flames too!
we whipped out sparky #1 and TDC'd it that way and the flywheel marking was in the right spot too.
i recon its 180 out now, it wont run and it does shoot flames out the carb.... HMMMM
