Originally posted by dubstar
View Post
1 of 2
2 of 2
A cream-filled mk1 build
Originally posted by browndizzle View PostYeah i saw a few online shops who sell door cards or seats complete also do cloth or material by metre, who would be the best for cloth to retrim the rears bud?
or VW direct with
Customer Login
A bit tricky with classic VW, price wise a bit cheapr than Hertiage but you have to put the effort in to email them, german to english translation isnt the best sometimes.
In terms of trimmers there is a good trimmer in melbourne called bus n bug but sydney i cannot help you for a trimmer
Originally posted by Neilmk1gti View Posthttps://au.vwheritage.com/ - free delivery with purchase of over $250. used them heaps, I even bought a meter of cloth to have my seat repaired, cloth matched good.
or VW direct with
Customer Login
In terms of trimmers there is a good trimmer in melbourne called bus n bug but sydney i cannot help you for a trimmerCURRENT: '76 MK1 Golf 2dr (1.8 8V, twin webers.. soon to be 16v)
PAST: MK5 GTI Pirelli + MK4 Golf 1.sick + MK3 VR6 (RIP)
Originally posted by maxmg View PostI actually really fancy the wrapped steering wheel that you're sportinghas character
Really suits the current interior down pat!CURRENT: '76 MK1 Golf 2dr (1.8 8V, twin webers.. soon to be 16v)
Originally posted by maxmg View PostYeah that's true, it needs a certain type of interior in order to fit in! What is the wheel anyway? I want to keep an eye out for one that I can wrapCURRENT: '76 MK1 Golf 2dr (1.8 8V, twin webers.. soon to be 16v)
Last edited by sports racer; 12-06-2016, 01:41 PM.1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
Originally posted by sports racer View PostSelling this steering wheel if you're interested.
[ATTACH=CONFIG]23699[/ATTACH]
I've got 2 of them, one in the MK1 and the same in the Cupra but I can't find a picture of the one in the MK1.CURRENT: '76 MK1 Golf 2dr (1.8 8V, twin webers.. soon to be 16v)
So not much of an update but I havent posted on this for a long long time.. this is what happens when you work 7 days a week, 5 of them being somewhat income-less? 😕 Havent had a whole lot of time to do much besides put new door cards in, rebuilt the webers, fixed some electrical/lighting issues and just overall, still enjoying the car itself!
The black carpet is still to be ordered, and so much more left to tick off the list! Might have to hit up someone about rebuilding the front O.Z's, i essentially want to take any need for spacers away (running 5mm atm) and run atleast 10mm less on the e.t. Could even do .5" larger lips and .5" smaller barrels? Anyone to confirm this?
The main thing that will be occuring is a build of an abf 16v I managed to get off Paul (sportsracer)! Thanks a million Paul! Will do cams and ITB's before dropping it in, just trying to get my head around the wiring and I want to possibly keep the original dash, despite it being alot easier to use the Seat dash?
Can anyone shed some light on the wiring situation between the mk1 dash and abf? I believe i have the older ceramic fuse box, so in terms of using the CE2 wiring from the Seat, what is the best aproach?
Cheers guys! Hopefully i can get the ball rolling again and start ticking more boxes off the list!CURRENT: '76 MK1 Golf 2dr (1.8 8V, twin webers.. soon to be 16v)
Originally posted by browndizzle View PostI'll take it off your hands if you chuck in a 16v on the side for free, Paul?1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
No wiring changes unless you're going efiuse a set of twin webers/dellortos
Sent from my D5833 using Tapatalk77 Mk1 GLS 2 door - That sinking feeling
76 Mk1 Swallowtail 2 door - Replace that BMW & 76 Sweetheart
Originally posted by Browneye View PostNo wiring changes unless you're going efiuse a set of twin webers/dellortos
But surely to wire up to a mk1 early ceramic fuse box etc, its a bit tricky? Not electronic savvy, trying to make sense of wiring stuff like diagrams off other forums like clubgti etc.
Like wiring to the dash and what sections to cut out of the Seat wiring that I wont need. Things like ABS etc obviously wont be needed, but what transfers over? Like ignition? (im running electronic atm) etc.CURRENT: '76 MK1 Golf 2dr (1.8 8V, twin webers.. soon to be 16v)
Not overly sure about how the 16v ignition works, but if you can source a mechanical advance distributor for the head, or mount the block distributor you already have (unsure if possible), you can use the electronic setup in the car already. In that case, you can just use the same wiring that's already in the mk1 with no ecu at all.
Running carbs and a dizzy you won't need complex wiring. Coolant temp, oil pressure, hall effect, alternator wiring, starter, thermo fan and reverse lights is about all that is necessary. You have all of these things in the current wiring loom for the 8v.
Dellortos are cheaper as well77 Mk1 GLS 2 door - That sinking feeling
Originally posted by Browneye View PostNot overly sure about how the 16v ignition works, but if you can source a mechanical advance distributor for the head, or mount the block distributor you already have (unsure if possible), you can use the electronic setup in the car already. In that case, you can just use the same wiring that's already in the mk1 with no ecu at all.
I think when i have the motors and looms in front of me, it might make more sense. Trace each wire one by one and bin everything not needed. Although apparently this 16v has been chipped too..CURRENT: '76 MK1 Golf 2dr (1.8 8V, twin webers.. soon to be 16v)
Test Slow
