G-8VXWWTRHPN My '91 MK1 Golf Cabby - VWWatercooled Australia
  • My '91 MK1 Golf Cabby
    Hey All,
    Hoping to tap into your knowledge bank. Picked up a second hand cabby that needs a little love.
    Here it is View image: cp4656993002825421423 1
    Steering rack is aparently cooked. Been quoted $825 fitted if my current rack is overhaulable. More if they have to replace it. Are parts like this hard to come by?
    Other work I've been told is required is a new left high beam light, new rocker cover gasket, steam clean engine, wheel alignment, reset rear muffler, locate/make new bushes for gear selector (Another $1k all up).
    Thoughts on any of this? I love my Golfs but not really a 'car guy' if that makes sense. Any input appreciated!
    Would love to keep her on the road.
    Originally posted by tafe View Post
    Hey All,
    I can't comment on the steering rack,
    ...but $1k for fitting a globe, a $10 gasket (I gave one away literally last week) and a wheel alignment that costs ~$100? if that? wow. Even the rear muffler, new, replaced etc should only be $100-200 and shifter linkages are easy to do yourself. Why does your engine need to be steam cleaned?
    Happy to give you a hand anytime man
    but don't get taken for a ride and let that turn you off mk1s. please.
    #mk1lyf
      I've got a rack you can have.
        btw, shifter bushes can be bought online for about $5-6 from places like GAP or vw heritage etc.
        84 MK1 GTI
        01 DC2R
          Fellas, it's people like you that give honest, hard working mechanics a bad name.
          Well done! Bet you there's nothing wrong with the rack, just needs balljoints replaced.
          That's a nice looking Cabby you've got there Tafe. Definitely worth keeping.
          Paul
            I've seen plenty of buggered racks,mainly due to split boots and moisture,dirt etc.
            Don't get the wrong rack though there are early non mounting bush ones and the later ones.
            Go to a VW specialist workshop or like most with old cars DIY.
            There are plenty of guys on this forum to help you out.
              Wow, what a great forum - Mate I'd be super appreciative of any help whatsoever. I'm in Melb inner-east, but will travel wherever. Feel like I'm at the mercy of mechanics (This guys was a second opinion and half the price of the first guy!)
              Really? Thanks!
              The mechanic was like, can't get parts for a car this old, and that he's gonna have to make them himself???
              Paul
              Cheers Paul, Hopefully with a bit of help I'll be able to. I want to keep it but after speaking with a couple of mechanics I was really nervous about being sent broke. Sounds like with a bit of know-how it's not gonna cost the earth after all. More than happy to put the time in, just don't have much know-how!
                which workshops have quoted you out of interest??
                shifter bushings - https://au.vwheritage.com/vw_spares_...umbStartRow=18
                84 MK1 GTI
                01 DC2R
                  Hey bud, try doing these jobs yourself. It'll teach you about the car and also how to work on them a little bit. Its all part of the fun.
                  Only The Good Die Young 45
                  For a better ride, go WIDE!!!
                  VS Commodore V6 Berlina- FOR SALE
                  1979 Golf Mk1- http://www.vwwatercooled.com.au/foru...one-92128.html
                    All of that's easy accomplished on a lazy Saturday afternoon by someone who knows Golfs.
                    Maybe a $200 tops to sort that lot out if you do it yourself with some advice form the brains trust on here.
                    Steering rack issues could also be due to a broken mount and might require a little welding. Nothing major.
                    If a steering rack mount is broken it also affects the gearshift as one of the levers mount off the rack.
                    Nice looking Car!
                    7? MK1 Caddy
                    79 B1 Passat Dasher Project
                    12 Amarok
                      Go to Volkscare in Boronia.
                      He is honest and wont rip you off!
                        Crusader Motors - Hawthorn
                        Car needs:
                        RH & LH stop light globes faded
                        Windscreen Squirter motor n/w
                        LH front seat belt not retracting
                        Inside boot side panels re-secure [due to electrical wiring]
                        Rocker Cover gasket [leaking oil]
                        Engine sump gasket [leaking oil]
                        New oil filter [leaking oil]
                        Oil pump seal [leaking oil] re-co pump
                        5 liters of engine oil
                        Welsh plugs [leaking water]
                        4 liters of 100% concentrated coolant
                        Rack ‘n’ pinion [has excessive free-play on RH side] re-co rack
                        2liters of power steering oil
                        Front brake pads are very low
                        LH & RH disc rotors machine [glazed and grooved]
                        LH & RH rear wheel cylinders [leaking oil]
                        2x 500mls brake fluid- bleed all brakes
                        2 liters of cleaning fluids
                        4x tyres [205/45zr16 fitted to the vehicle are too wide, rubbing on the chassis and under minimum
                        clearance between shock absorbers] 195/45zr16 recommended
                        4x wheel balance
                        4x wheel computer alignment
                        "It is hard to determine exact cost involved for the listed repairs and you can see there is decent amount of work involved, an approximate price range is $4000-$5000. The reason for a $1000 bracket is due to some parts that may be required however cannot be identified untill the work coimmences and only when its its process. As well as the labour involved can vary and can only be accounted close to completion of the work. "
                        The Workshop - Hawthorn
                        "Steering rack price is $825 fitted. This is if your own steering rack is overhaul able, if not we have to try find a second hand unit that is. According to our steering specialist they have a tendency of rusting internally which makes them useless and have to be thrown away. We are not sure what a second-hand unit is worth, apparently we’ll cross that bridge if we need to, however it will be a cost on top of the $825
                        As for the other work required from the report I’ve estimated it at approximately $970. This includes left high beam light, new rocker cover gasket, steam clean engine, wheel alignment, reset rear muffler, locate/make bushes for gear selector,
                        Rectify right front wheel guard hitting tyre.
                        All the above mentioned prices are inclusive of GST, parts, labour and oils. As with all quotes please remember they are only a guide and do not allow for the unseen."
                        Nice looking Car!
                        As you can see, pretty huge difference between the inspection reports (they barely converge but for the steering!)
                        I'm pretty inspired by the MK1 passion here so I'm gonna follow your guys lead and try and do some stuff myself. But... Where to start
                          That's not the symptom of a faulty rack otherwise there would be movement on both ends. Sounds more like inner tie rod end - less than $100 to fix.
                          Start with whatever you're comfortable with and ask for advice as you go.
                          16" wheels are a bit too big for a MK1, 15s suit much better but I'm biased - I'm looking at upgrading my 15's to 16's on my MK2 if ever you want to swap.
                          Paul
                            +1
                            Boris at Volkscare is a legend. I got my roady done by him and vicroads regoed it the same day! Cost me 220 with a very similar looking list. I did do almost everything myself though haha. Just listen and learn and you'll save yourself a bunch from dodgy mechanics
                            77 Mk1 GLS 2 door - That sinking feeling
                            76 Mk1 Swallowtail 2 door - Replace that BMW & 76 Sweetheart
                              Car needs:
                              4x wheel balance
                              You start on what you feel is easy enough for you so that you get the hang of it and progress to the more harder stuff until all is done. And I am pretty sure once you start and you have questions you can post them on here and there is plenty of guys with an abundance of knowledge who can walk you through it step by step.
