Hello, my name is che from coolangatta. qld.
I just bought a 1976 Golf LS with 1600cc, K-jet.
Car just goes great! except has a few issues..
1. tacho is not working. And brake, hand brake warning light is off (can't find the wire switch)
2. has K-jet but the belt is off from the alternator I reckon
- previous owner told me there was a backfiring, misfiring before he took off the belt for fuel injector.
now it seems working real fine without the belt.. but couldn't it be better with k-jet working right?
and I can smell the fuel from inside of car.. it could be running rich or fuel leak?
is it related to k-jet? any ideas please..
3. transmission oil is leaking a little bit..
4. there's a switch for the cooling fan on the dashboard (modified)
I have to switch on as the temp go higher than mid
Isn't this supposed to work automatically?
-fan is working fine as switched on and temp stays on mid but just annoying to do it manually.
5. he told me there was a fire on dash from bad wiring..
now dash is burnt and cluster looks really bad. maybe it caused the tacho and brake warning light i guess.
can I get it anywhere?
6. where can I get a locking fuel tank cap?
I will be appreciated with your helps..
hope to see mk1 owners on the road! never seen one around here!
