Nah its alright, i've already got a low beam relay set up, just gotta set up a high beam one now. Im too lazy to do it though, so im driving with HIDs ahaha.
Seems to be coming along nicely, but with the weather, we are all slowed down
So got sick of the stupid fuel consumption !!! half a tank got me 80kays of town driving 20L/80kays!!!
So i got around to putting a 32.36 DGAV weber on her, and WOW. started first pop when fuel got to carb. Idled and everything straight away.
Got a bit of tuning to do obviously, timing, jetting ect. I get alot of hesitation and it dont really want to rev past 4k under load.. BUT, it will pull from 60kays in 4th pretty well :S
Got a mate sending me some jets, so will have a fiddle next week. does sound very throaty when secondaries hit
Good to see you value adding.... To an earlier comment.... It wasn't headed for the scrappers, so Dan didn't really save it.... But it is good to see someone doing something with it. It sat around at my place for a year at least...
Too many dubs to mention.... Erika (2008 Mk5 GTi - Graphite Blue, DSG, Leather, Xenons, RNS510) Matilda (1991 Triton Flat Tray - White, 5sp Man, Vinyl Bench, Radio)
can tell it had been sitting for a while, rego papers said 2004....
As it is ive had to replace
Dizzy cap,
rotor button
points
plugs and leads
fuel hoses and filter
radiator hoses
coolant hoses
radiator fan
all the brakes and master cylinder and booster
drivers seat base
engine wiring harness
gear shifter bushes
and now the weber setup.
I added the small bumpers and duckbill
Coilovers should be landing soon, want to try them out in this for a while... (they paid for, might aswell use them)
All i need now is a weber filter, and a handfull of jets and a sunny day
so my jets came in yesty.
Got a chance to fit them this morning (yay, sunshine )
All i can say is WOW!!! :O :O :O
Previous setup was
primary seconds
50 55 idle
132 130 main
170 160 air
That setup to me seems pretty lean, especially on primary side.
New setup is a mixture of 1.6L setups ive been researching on. came up with a "middle" setup. seems its the default weber setting too.
Primary seconds
55 50 idle
140 135 main
165 160 air
Overall it runs great, little flat off idle and up to 2k. going to play with idle jets and mixture screw as that flat bit is in the idle circuit.
Once it hits 2k 2.5k holy craaaaaaap! the the little 1.6 really boogies
Next step is ignition, electric setup to ditch points, should improve it alot.
