Inlet manifold still not coming off!
  • Inlet manifold still not coming off!
    the inlet manifold is still not coming offf. i have taken out all bolts out and given it a healthy whack with a block of wood and a sledge hammer (yes i was being careful).... nothing. help????!!!!!
    I know you tried a block of wood and sledge hammer, I would try a rubber mallet if you have one. A constant tapping while wiggling may be what it requires?
    Do you have any movement at all?
      Stress or strain??
      From my experience you need to apply pressure to the off-side of anything that you are trying to separate. Doesn't matter if it's a ball joint, track rod end or cylinder head it needs to be levered away from the component with the greater mass before applying a shock. So in the case of your manifold (which I haven't seen and am only imagining) put a lever between it an the block/head/immovable object and then hit with a fibre/wooden/rubber mallet to dislodge. But, before you do anything more, check and double-check that there isn't something that you've missed still holding it on. I've done it a million times and cursed myself blue the same number.
        Of course the little flat bracket from the inlet manifold to the exhaust manifold is undone.
        Widebody Cayman S Turbo, 83 ur Quattro
        2000 996 C4 cab,12 Scirocco R OEM+ STG2+
        72 914 (3.2S boxster pwr), 92 G60 Corrado
        76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
          Yeah if you are certain its undone. A scissor jack could be the go.
            i see no bracket?!
            absolutely no movement and no rubber mallet in site... someone suggested gasket remover>?
              one bolt in the bottom of the inlet manifold with a flat bracket between it and a bolt in the top of the exhaust manifold.
              its usually rusted. just undo it till the bolts snap then leave it off. 12 or 13mm spanner.
                you did remove the bolt and bracket attached to the exhaust manifold right ?
                  there aint no bracket there mate i mustve taken it off
                    How about you count the bolts that have been removed and someone on the forum can tell you if that is all. Just to make sure
                      i was just there mate,, i checked all the holes in the inlet manifold... i checked behind the back of the manifold for the bracket which is removed.... everything is not there and its still hanging on for dear life... and i just grazed my elbow and hand
                        Hope your ok!
                        Now go to the fridge, grab a coldie. Knock the top off it, enjoy it while looking at the manifold contemplating. "why"?
                        Seriously though they can be damn frustrating. For memory years ago you could get a bonding compound for manifold/exhaust gaskets that went rock hard, it may have a similar product on it.
                        Once finished your beer, grab the piece of wood and sledge and lightly tap it off. We are all cheering for you.
                          im fine thanks wolsburg...to quote monty python... "its only a scratch"
                          i have tried the sledge hammer and block of wood... lightly... what would happen if i went all out and belted the $h1t out of it???
                            Have you thought of taking the head off?
                              why???????
