It Lives!
Just fired up the new motor. Heaps of compression! I haven't driven it yet it got too dark, cold and late to do much else today.
Rattled a bit at first then quietened down, I forgot these things have hydraulic lifters!
I just let it idle for 10 minutes while I checked for leaks and kept an eye on everything.
The throttle is super responsive, the 1600 wouldn't respond to throttle input like this! Just gave it a couple of blips, no lag, no bogging down etc.
All the timing is just set at zero at the moment , I'll have a crack at tuning it tomorrow after I replace the points.
There's two oil pressure switches on the Cordoba motor, one of them is shorted to ground with the engine off (the idiot light switch). The other one is open. I'm hoping it's closed when the pressure is OK so I can use it as a safety for the new electric fuel pump, I'll check it out tomorrow.
Only one water leak, unfortunately it's the heater core I replaced at the same time. Doh! I'll pull that out tomorrow and check it out too.
Pics and road test tomorrow!
Pete
Pete
