I had same problem,
replaced leads, plugs, points, cap, Coil, Carby, gaskets.
Did timing, mixture, replaced vacuum hoses ect. And it STILL wouldnt idle right.
I just put up with it
Are you sure you havnt got timing belt one notch off? i did that and it idled bad
I had same problem,
I supose i could just put up with it, it does sound kindo agressive, although i do want to do it properly.
Ive done the timing starting with the belt, so it shouldnt be off.
I found the problem today by spraying carbie cleaner around the base of the carbie. Its got a vacume leak on both sides of the carbie.
I went out and got some thicker gasket paper, 80thou this time, cut it up, slapped it on and it was fine for about 20sec untill it started leaking again. I tried to tighten it down even though your not supposed to but that didn't help.
I would really like to get my hands on a nice new gasket that was made for the Passat manifold, does anyone know if they are still available?
Tomorrow i am going to try seal it up with silicon gasket maker and see how far i get.
On the up side, i got the tie rod end undone thanks to my neighbor Tony and adjusted the toe so that the wheels are straight
Carefull you dont suck silicone into the carby mate, that will stuff it right up.
If the carby is a webber it is proablly a generic webber gasket. Draw a template of what you want and take it to a proper old school car shop. You will probably find that its the same as the gasket on an old escort, or holden, or something with a webber and thats what you need to order. Sounds like you are getting close mate, keep at it.
19-20/6 Badgally Road, Campbelltown, 2560 02 4627 3072 or 0423 051737www.camdengti.com
I went and got some gasket maker and while taking the carbie off a nut or washer fell in to the manifold. I didn't notice until i put everything back together and started the car. It made its way past the valves and in to the block smashing the spark plug in cylinder 1.
One step forward and two large steps back. Stupid cars.
