Changing the rear muffler will only change the sound of the drone. I found that out the hard way on the Thunderbird i had and a friend's Civic. You'll need to add a resonator somewhere towards the middle. Not sure if the exhaust on an Mk1 is similar routing to the mk2 (I'm guessing it is as an Mk6 has a similar routing to a mk2) then you can add a small resonator in front of the axle.
Team Green 16V
Originally posted by Rob Burns View PostChanging the rear muffler will only change the sound of the drone. I found that out the hard way on the Thunderbird i had and a friend's Civic. You'll need to add a resonator somewhere towards the middle. Not sure if the exhaust on an Mk1 is similar routing to the mk2 (I'm guessing it is as an Mk6 has a similar routing to a mk2) then you can add a small resonator in front of the axle.
By Local do you mean the Blue Mountains?
A good friend of mine had a family friend in Penrith who owned an exhaust shop and did excellent work. I don't know if he's still around but he was just near the Westbus on Mulgoa road. Cobra exhausts or something like that.
Originally posted by IH8 View PostComing from the Dragster guy?
