Nope its a 76. had the smaller lights and a dent, hence my justification for the larger lights. They nearly fit. Will with a bit of fettling.
My Golf Rebuild
Been undercoating in and out. Just put in lowered back axle and rear anti roll bar and mounted up the electric fuel pump. Back brakes are on, lines are not. Next job is fuellines to the front of the car and brakes to the front of the car. Then the back is finished. Also put in my slick fuel neck purchased from Syncro and a shiney thing from ebay. Pic tomorrow.sigpic Camden GTI Performance. VW / AUDI Specialists
Shiney filler ring, from ebay. Blue petrol inlet and new springs. I`m not happy with the ride height, but the car is very light at the moment.
anti roll bar.
adjustable lower suspension arm on medium setting, fuel filler neck and the bottom of my car. That took me all day.
Car is on the floor, tank is in, fuel pump is in. Now brake and fuel lines...sigpic Camden GTI Performance. VW / AUDI Specialists
Just finished putting sound deadener on the floor and firewall of the car. I want it quieter than a standard golf and it all helps hold it together and keeps the rust out. Fishoil too. She smells a bit at the moment.
Means I can start wiring and fittings!
Also swopped the gearbox outer ends on my 16v box to 90mm, so as to utilise the dozens of Mk1 driveshafts I have.
Out with the old and in with the new.
Box is now ready to go in and as soon as I get a clutch spring, its going onto the engine.
Also been making up a custom and much improved brake linkage and booster. Pics soon.sigpic Camden GTI Performance. VW / AUDI Specialists
So I got a bigger master cylinder from an Audi, adjusted the shaft length with help from dubstarmk2, cheers Al. I welded another steel piece along the back of the bracing bar to stop it flexing and made the rod fatter. Then I cleaned all the linkages, replaced the washers and cleaned everything. Works great now, no flex and instant response. On the bench at least!
Its going in the car soon, closely followed by the engine.sigpic Camden GTI Performance. VW / AUDI Specialists
Always fishy goings on in my garage mate
Just like a bit of colour to complement the chrome and black of my engine. They are the only two acessory colours. I like the blue and am undecided on the light green.
They look good against the oak.
I`m 90% happy with the Oak Green, and the guys owe me a free touch up when its back together. Then it`ll be 100%. Its a great colour looks sparkling in sunlight and deep and emerald in shadow.
How about sharing the driveshaft secret with us all, via a post in Tech Tips?sigpic Camden GTI Performance. VW / AUDI Specialists
Its a great colour. So is Dragon Greensigpic Camden GTI Performance. VW / AUDI Specialists
I reckon it`ll be driving round by christmas. It`ll be making noises in a few weeks. Thanks for the support for the lollipop colours, you only see the odd bit of it and it brightens up the engine bay. Yes may do hose braiding, but not high on my list of priorities.sigpic Camden GTI Performance. VW / AUDI Specialists
Update Late November 2005
OK Christmas is coming up and the car is not making noises.
I have had the suspension in and out a few times and messed around with fuel lines. The back is now finally on the floor and I`m happy with the ride height. The front is currently getting brakes and then will be on the floor too. The engine is next to the car nearly ready to go in. 9A 16v. and my KR Cams arrived early, so that should give it the required kick.
Hopefully I will get some time soon to Bolt the motor in and then it`ll start to look like a car again.
Pics as soon as I have something to show you. Still hopeful for the VW nationals at Easter.sigpic Camden GTI Performance. VW / AUDI Specialists
Front brakes are done, Mk2 Calipers and Vented Disks on Mk1 1983 hubs.
Put the mags on it and its a rolling shell. Sits a bit high at the front, but sticking the engine in should fix that.
Currently sidetracked on other projects, but will be spending some time on the Mk1 soon.sigpic Camden GTI Performance. VW / AUDI Specialists
