Hey guys, i was curious, rather than using the European style and using bolts/studs, is there a way to put in bolts on the hub, so that you can use a nut instead. Kinda of like a Honda?
For example, for people using spacers, they need to have longer bolts, however what if a bolt was put in and inverted into the hub, that way spacers could be used, and you could use nuts instead. Which would make it a hell of a lot easier to put a wheel on
I assume its easy for the drums brakes, but what about discs? I hope i am making sense.. hahah
Any advice would help.
