Good stuff.
You can actually do it from the top without removing the wheel and inner guard.
Yeah I figured it was possible, wanted to get down there and check for old belt residue and clean out a bunch of metal pieces from the old pulley going bang though.
I was working under the impression that the centre bolt was a T50 Torx bit at first and kept having troubles with it slipping, upon closer inspection it was a size 10 spline bit, had no issues once that was in there.
Some of the kits on the net include the Torx bit for working on other cars. While working on mine during the inspection I tried a long 10mm XZN/multispline that I already had in my toolbox. I only had to order the 33 tooth one, from memory around $8 including postage from China, bargain.
Numerous Mk1 Golf diesels
During my inspection, I removed the wheel & inner liner as VW suggests & thought afterwards that it could all be done from the top. The only problem I could see is to make sure the multirib belt was in the correct position on the lower pulley[bit hard to see] but certainly doable.
Jets can correct me if I'm wrong, but to the best of my knowledge there are two female splines as part of the pulley assembly. The 33 tooth one is used to stop the alternator from spinning while undoing the inner bolt that holds the pulley itself in place.
Just to clarify, there is only one female spline as part of the pulley assembly. You are correct with the rest of your instructions as is asa572.
