BKD Engine diiferences???
  • BKD Engine diiferences???
    Had the turbo blow in my Late 2006 MKV TDI last week.
    Sourced a low k BKD engine from a 02/2009 MKV so was just going to do a complete engine swap.
    So the engine turns up this morning but the inlet manifold is the plastic type, mine has the alloy type.
    Just wondering if anyone knows if it is a straight bolt in with the plastic manifold or
    if I need to swap them?
    Thanks,
    Andy
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
    Straight swap, VW moved to nylon inlets to both lower costs and drop heat transfer. You sure the 2009 engine is still PD MKV?? Can you post pic of top?
      Hey Greg,
      yeah it's a PD engine.
      Sorry for the confusion, the car was complied 02/2009 but was built 05/2008.
      Thanks for confirming it's a straight bolt in.
      Andy
      MKV Jetta FSI DSG
        how many km on your old engine mate?
        '98 Mk3 Cabriolet 2.0 8V
        '99 A4 Quattro 1.8T
          around 198,000.
          engine is fine and I have never had a problem with it other then the turbo going.
          I was going to just get a new turbo but I got this engine with turbo, DMF (which was starting to go) so I'll just replace the lot.
          Anyone close to Lake Macquarie/Newcastle have a BKD cam locking kit for a timing belt change?
          MKV Jetta FSI DSG
            I do, but not close, so happy to be plan B.
              My turbo went also at 192k. I have the same engine. Whacked another turbs and intercooler on there and good as gold. I was going to go down your route with replacement engine but until something breaks internally, I figured there was just no point throwing $ away.
              Sent from my Redmi Note 2 using Tapatalk
              2007 Golf MKV 2.0 TDI DSG
              | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
                I've got the tools. I'm local too....not sure but I think my dad has borrowed them though - when do you need em?
                '99 A4 Quattro 1.8T
                  I have a timing belt kit coming tomorrow and I am going to try and fit the engine over the weekend.
                  Let me know if you can get it.
                  Andy
                  MKV Jetta FSI DSG
                    I got an engine with 90,000 k's on it with a turbo, good dmf (which need replacing also) for a price that I couldn't even find a second hand turbo for.
                    I have a work shop (where I work) with a hoist so an engine swap isn't a big deal.
                    MKV Jetta FSI DSG
                      Thanks for the offer Greg.
                      If all else fails I will get in contact.
                      Andy
                      MKV Jetta FSI DSG
