103TDI turbo whistle
  • 103TDI turbo whistle
    Hi All, our Octavia has developed a faint but definite turbo whistle. It comes on just after pressing the accellerator along with the boost (torque) but then wains even though the torque remains. as the revs rise it seems to come on again. Its only slightly but distinctively louder than it was before (distinctive enough for my wife to notice..!)
    Any ideas on what this could be?
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    A 'defeat device' waiting to be executed.....sorry, couldn't help myself.....
      So you think its got something to do with the egr then???
        errr no, but you look like a candidate for a 'call up' which might fix it anyway.
          My Yeti is in the recall.
            i dont think the dieselgate caused my car to whistle
              If it's in the recall I'd wait and see what happens.
                Boost leak I reckon, the intercooler connectors are notorious for it, but even the slightest leak somewhere will give you that sort of noise.
                  I've got that slight whistle on my Passat, I just thought it was the turbo spooling.
                  Mine: MY10 B6 Passat Wagon Highline Granite Green. Upgrades: Roofracks and Child restraints.
                  Hers: MY12 B7 Passat Sedan Highline Silver. Upgrades: Child Restraints
                  Dead: MK4 '99 Golf - Engine Dying, B6 MY08 Passat Sedan - Blown Engine.
                    the intercooler connections must leak a bit as there is some oil wetness around two of them. is it simply a matter of replacing an oring to reinstate the seal?
                    Occy was built Jan 09 and is apparently not affected by dieselgate....
                    "Dear customer! The vehicle with this VIN code is not affected.
                    Please enjoy your ŠKODA." (and its whistle)
                      Leaking is also normal, and new o-rings donlt do anything as the connection is poor to start with, even the Porsche's suffer from it. You can simply ignore it, as it;s no big deal, but if like me you want that last kw, then undo the clip ( note how and where it sits as you have to get it exactly right to save dropping a hose on the road ) clean up the connections with some degreaser and prepsol / metho etc, and silastic them together.
                      Afraid other than that, you will have to live with it. Point it out next service, maybe they have a dealer fix too.
                        I had the clamp come loose off the exhaust outlet of the turbo whilst at a track day in Brisbane.
                        Quick trip to Jmac's workshop and a new bolt fixed it straight away.
                        Sounded great though!
                        Not including hers...
                          Why can't you buy a 'bug' that transmits on a car radio frequency the sound of the exhaust at the outlet?
                            My trick is to pull it apart like greg has said, clean it, and then lube the o ring with petroleum jelly. It will swell a bit once you put it back together (takes hours) and might seal better (for a while).
                            '98 Mk3 Cabriolet 2.0 8V
                            '99 A4 Quattro 1.8T
