Engine warning light.
  • Engine warning light.
    Hi Guys,
    Today while driving the engine light appeared on the dash and hasn't extinguished since.
    The car starts normally and drives normal as well.
    Now I am a bit concerned driving the oil burner and the dealer can not fit me in to have it checked until 8 July.
    Any recommendations where I could have it looked at sooner? What it could be?
    It is a Golf Mk5 TDi Pacific MY2008 and has always been filled up with BP Premium Diesel
    Greetz
    NS
    VW Golf MY09 MkV DSG 2.0 TDi Pacific United Grey
    Opal Head Unit - Jomlook DRL
    WOB = Wolfsburg - Vfl Wolfsburg Deutscher Meister 2009
    It could be anything, I had the engine light come on once, I had it scanned. One of my coil packs went and had to be replaced. The engine light could mean a few things.
      There's a few places in in the northern suburbs of Melbourne if your located in Victoria.
      Volkwerke, greensborough
      Volkhomes, thomastown
        I know Melbourne's North is growing, but not THAT much)))))
          I will have it scanned and thanks for the advice. : )
            What was it?
              Originally posted by sjhuybens View Post
              What was it?
              The culprit was the EGR Valve and Throttle Flap.
              Replaced and all good now.
              Was advised to give the TDi a good flogging on the freeway from time to time due to mainly city stop/start driving.
              Regards,
              NS
                How much did it cost?.
                  Regards,
                  NS
                  That will help with the turbo's VVN and won't do anything for your throttle flap or the EGR - you need the oil catch can (Provent200).
                  Performance Tunes from $850
                  Wrecking RS OCTAVIA 2 Link
                    Exactly what I'd have thought......lots of 'blow-by' oily gases to be dealt with at speed under load.
                      Maybe I didn't explain it correctly. Is the flogging of the engine related to keeping the catalytic converter free from clogging up? That is probably what they meant when I was told about flogging it.
                      Btw, where can I have a Provent 200 installed and at what cost?
                      The EGR and Flap cost me about $1400 supplied and installed at Muller and Muller at Lakemba.
                      Regards,
                      NS
                        Regards,
                        NS
                          Regards,
                          NS
                          The flogging is to keep the turbocharger vanes from getting jammed with buildup of soot.
                          $1400?? Good grief! I have the same light on - a VCDS scan by a very helpful forum member gave a TPS inconsistent reading code so I was fearing this would be the cause. At least I know what to expect
                          Meanwhile, the car runs just fine.
                          Resident grumpy old fart
                            Oh!
                            there was I thinking that was quite cheap.
                              EGR flap can be had from ebay uk for about $150 used, and darkside developments have them too from memory. Dead easy to swap out.
