From reading threads on o/s and 4WD sites, the older style diesels also get reduction in the pump noise more than the injectors. Being at much lower pressure than a CR HPFP, maybe these can get quieter with a lower amount of additional lubrication (but without the full benefit of the other effects that most of us have experienced)
1 of 2
2 of 2
2 stroke oil (2SO) as an additive to diesel fuel
Resident grumpy old fart
I think 1:300 is close enough to 1:200 to get good results, just not the optimum amount for the best results? He was being cautious just in case and I don't blame him.
I was amazed at the results people got from their Toyota 86/Subaru BRZ 2L petrol engines with as little as 1:1000 being enough to shut up some noisy HP DI fuel pumps and 1:600 being the optimum 2SO ratio for petrol engines. A common observation from that was that the engine was smoother as well as being quiet again.
You could be right about the pump being the bigger source of noise on the old school diesels.
How's this for a result with 2SO?
My lawnmower is an MTD 21" rotary with 5hp Briggs and Stratton side valve, I bought it new in 1991. Original everything apart from one blade change about 1996, single heavy blade. I've looked at the plug maybe 3 times, tapped it down and put it back. The air filter has been cleaned perhaps 6-8 times. 4 oil changes?
It starts first pull 9 times out of 10 but for the last couple of years has been failing to idle properly and cutting out.
I added a good dose of 2SO when I filled it up and used it last time. Today I used it again and the idle is now almost perfect, a touch fast but that's being picky. That mower is like my 16 year old dog, every day it still works is a bonus.
I've got a new self propelled mower with a Kawasaki engine but hate the thing, so use the old girl instead.
Another use for 2SO.
Hi All,
I have been reading this thread with interest since the beginning and now it is time to add my $0.02.
This weekend we went to the Margaret River region. Romantic, aren't I
In an earlier post, I mentioned that I used Penrite DPF Cleaner during our Christmas holiday, also to Margaret River. We achieved 6.7L/100km both ways.
On this trip I added 350ml of Castrol Activ 2T and topped up with BP Ultimate. All of the variables were the same. ( aircon, cruise, speed, and ambient temp). On the trip down I averaged 6.3L/100km traveling mostly at 120km/h on cruise. On the return trip I achieved 5.5L/100km in near identical conditions.
Now for the subjective bits. The engine seemed quieter and smoother and more eager to rev higher. Overtaking was easier.
The fuel consumption numbers don't lie. I am not sure whether I will add it at every fill or use it occasionally like a fuel additive, but I am impressed.
As always caveat emptor.Last edited by Amalgam; 17-02-2015, 12:25 PM.
Thanks for that informative post.
That's an decrease in fuel consumption of almost 12% overall and almost 18% for the return trip! (that's by dividing the new consumption vs the old - I could inflate those numbers by working the figures the other way) While I am an advocate of using 2 stroke oil as a diesel additive, there must be some other factor at play that helped out on the return trip to produce such a stunning improvement. Was there a tail wind most of the way coming back?
I assume your car has a 70l fuel tank - could you also tell us what sort of car and engine is it and how much mileage has it done? And what was the distance of the trip down to Margaret River?
Even the 6% decrease on the trip down is impressive enough for me to want to run it for a couple more tanks, if only to see if there is an improvement in the "normal" driving fuel consumption. Plus the subjective noted gains in the behaviour of the engine are worthwhile too.
But if you decide not to use it in the next fill, it would be interesting to know if you feel any immediate difference once your car is running straight diesel again.Last edited by kaanage; 17-02-2015, 06:41 AM.Resident grumpy old fart
All the variables, environmental and vehicle related were similar ie there was no howling headwind or tailwind, the load was the same except for the fuel as we did not top up and the gauge was just under half when we returned home, the route was exactly the same.
The distance between my house and the hotel was 260km and the total distance travel inclusive of side trips in the region was approx 700km.
The car is a MY12 Passat 125TDI with 36000kms. Tyre pressure was set to 38psi when I topped up.
From my post in Christmas 2012 I was achieving high 5L/100kms when the car was 5000kms old. I am therefore guessing that the 2SO acted as a "cleaner" removing deposits from the injectors and other parts to return the engine to "as new". If this is the case, it is interesting to note that I did not achieve similar results with either LiquiMoly or Penrite DPF/Injector additives.
I would be grateful if those with a more indepth understanding chime in.Last edited by Amalgam; 17-02-2015, 12:31 PM.
That's quite a result!
From the balance of the reports so far about a 5% saving in economy is the average. Was that calculated at the pump or from the readout?
Not that it makes any difference because it's the comparison that counts. I see your car is rated at 5.7L/100km and you averaged 5.9L/100km over the trip. It's interesting that your fuel consumption has increased from 5,000km to 30,000km and your suggestion that the 2SO has cleaned the engine sounds the only viable explanation to account for the over 10% improvement in economy.
You could narrow it down to the injectors being the most likely benefactors.
You mentioned the engine was quieter. Was it quieter at 5,000km and then got progressively louder, that's a hard one to be aware of.
I'm just wondering if it was quieter and now it's back the way it was, perhaps even quieter?
With that fuel consumption you could use the same way to calculate how much 2SO to use as I do. Set the trip at each fill up and just add 1/3 of the km in ml. 600km = 200ml It should be 180ml at 600km for yours but it's near enough.
Can you tell when your DPF is doing its thing? I can honestly say that I never been aware of that which is strange because I listen out for anything out of the ordinary, probably a habit from driving so many old bombs in my youth.
Thanks for the feedback, especially with such positive results. As for using it once in a while as an additive to clean the system or whether to add it at every fill is a decision you have to make. Once you stop, if it returns to it's previous diesel clatter, you might use it again just to shut it up and enjoy the smoother, livelier engine. Then there's the fuel consumption but for me, the biggest incentive is the thought that it's extending the life of not only the engine but the fuel system and even the exhaust components.
Looking at the Mean Sea-Level Pressure Analysis for the 14th of Feb on the Bureau of Meteorology site suggests that for that region there was southwesterly wind for the whole morning from the high pressure system off the coast (after the cold front that came across around midnight) switching to a southerly as the high pressure system moved further across.
Looking at Cunderdin and Busselton Airport's observations for the confirm this
So most likely headwind/crosswind on the way down, tailwind/crosswind on the way back.
Locals would be best to confirm or deny this
Cleaning off the carbon deposits on the injectors and from the head and piston crown would seem to be the most likely cause for the majority of the economy improvement with some improvement also due to the engine running in more.
Thanks for the additional information, AmalgamLast edited by kaanage; 17-02-2015, 04:42 PM.Resident grumpy old fart
for using it once in a while as an additive to clean the system or whether to add it at every fill is a decision you have to make. Once you stop, if it returns to it's previous diesel clatter, you might use it again just to shut it up and enjoy the smoother, livelier engine. Then there's the fuel consumption but for me, the biggest incentive is the thought that it's extending the life of not only the engine but the fuel system and even the exhaust components.Last edited by Amalgam; 17-02-2015, 05:42 PM.
My thoughts exactly.
Originally posted by kaanage View PostLooking at the Mean Sea-Level Pressure Analysis for the 14th of Feb on the Bureau of Meteorology site suggests that for that region there was southwesterly wind for the whole morning from the high pressure system off the coast (after the cold front that came across around midnight) switching to a southerly as the high pressure system moved further across.
So the headwind coming and tailwind leaving fits perfectly. no wind from the north for at least a week.
It swings across from the SW later, as the sea breeze comes in.
Amalgam,
I tried to post as you did but it turned to mud so it's just the replies below and I hope it makes sense?
That is what I expected but good that you confirm. It's certainly what I have found.
So having tried bio diesel blending and knowing the lubricity is similar, how do they compare in practice?
I did get that once when I stopped. The fan was going flat out, the temp read normal so I walked to the front and had a look under the engine expecting to see coolant but there was nothing, then the fan stopped. Good to know.
It is strange. 2SO punches way above it's weight considering the tiny amount being used. When the inevitable question gets asked on a regular basis, "if it's so good why don't they add it at the refinery?", you have to wonder why they don't. It's a match made in heaven.
I parked next to a Passat Wagon this afternoon and had a good look. It's a classy car. With that extra grunt from the higher rated engine and 100kg lighter than my Yeti it must be a good driver's car.Last edited by CardinalSin; 18-02-2015, 12:05 AM.
Originally posted by Amalgam View PostIIRC the engine is now as quiet or quieter when compared to new. I was 'blending' my own B5 with 7L of Gull B20 and topping up with Ultimate/Vortex. Studies show that B5 and 1:200 2SO have similar lubricity.
That would mean it was definitely more than the lubrication effect of the 2 stroke oil that was causing the improvements.
Was the engine better with the "B5" than with straight diesel?
Sorry for all the questions but you've tried more things than I have and the direct experiences are the most valuable ones.Resident grumpy old fart
Originally posted by kaanage View PostSo are you saying that your Passat runs quieter and more smoothly with 1:200 2 stroke oil than with the "B5"?
Gull stopped retailing B20 6-12 months ago, so my comments are all from memory. I believe that B5 and 1:200 2SO are comparable in their noise reduction. Here is a link to a lubricity study comparing B5 and 2SO
Originally posted by kaanage View PostWas the engine better with the "B5" than with straight diesel?
I always felt that B5 was quieter and smoother than straight diesel, even Ultimate/Vortex.Last edited by Amalgam; 18-02-2015, 11:52 AM.
