2 stroke oil (2SO) as an additive to diesel fuel
  • Given what Greg Roles has said about flash points and looking at these and auto ignition temperatures of 2 stroke oils (where these could be found), I now feel I was wrong with my previous hypothesis about the action of 2 stroke oil (and other non-metallic catalyst diesel additives) for more complete combustion and smoother running.
    The action would appear not to be more controlled ignition but more complete combustion via the extension of the burn interval, since the flash point of 2 stroke oil is pretty much always higher than that of diesel. This would go along with the clean burning requirements of 2 stroke oils (needed to prevent deposits in 2 stroke engines)
    Thanks for pointing us in the correct direction, Greg.
    Anyone know of a university needing a doctorate thesis topic?
    Resident grumpy old fart
    • Better, more complete combustion also explains the reduction or elimination of smoke and the dramatically reduced emissions shown from annual testing in Europe.
      I had a quick look for a post on reduced soot levels using 2SO and found this one which i'm sure is a copy and paste from the epic posts about Mercedes using it on Frelander?
      If the soot levels are reduced by 50% on a vehicle being tested without a DPF it seems reasonable to assume that on a vehicle equipped with a DPF it should half the number of regens and double the km's before the DPF reaches maximum particle capacity.
      "The measured cloud-factor of a diesel engine without use of 2-stroke oil has been 0,95.
      The same factor with the use of 2-stroke oil has been 0,47 - reduction of nearly half of the soot particles.
      Besides this, the use of 2-stroke oil in the diesel will increase the mileage by 3-5%."
      Reducing fuel consumption
      There are more references to the reduced emissions.
      • I carried out another observation, but this time on my direct injection petrol car.
        Most DI petrol cars have a diesel like clatter at idle. Obviously not as severe as as a diesel, but still noticeable. Especially as the injection pressure increase in newer models as manufacturers chase ever increasing fuel economy and lower emissions. The Toyota GT86 / Subaru BRZ are notorious for this.
        After reading the GT86/BRZ forums and the results I had with the Passat, I added a 1:600 dilution of Castrol Activ 2T to my last tank.
        The car is my daily driver around town ( the Passat is the wife's ) and therefore the driving conditions can be variable. Approximately 50% free flowing arterial roads and 50% freeway with little to no stop start traffic.
        There was a significant reduction in idle clatter but most surprisingly a significant reduction in fuel economy from 7.5L/100km to 6.8L/100km. All the data is from the MFD.
        • brad's car is also a gasser. I don't think it's DI, though
          • Another really good result. I expected the noise reduction from the HP injection pump on the motor but the fuel consumption difference is surprising. That's about the same as you got from the diesel.
            The MFD reading as a comparison has to be accurate. The calibration is usually out by 5-10% the same as the speedo but everybody just accepts that it reads a bit over, so 100kph is really about 94kph. Same with the MFD fuel and 5.9L/100km is really about 6.4km/100km. Anyway 6.8 divided by 7.5 = .905 so a saving of 9.5% which is amazing.
            Another benefit should be that it will clean the injector tips which tend to get fouled with carbon in DI cars.
            Maybe the fuel consumption is a result of reduced friction in the HP pump, piston to bore, valve guides and in time, the cleaning of the system? It's hard to imagine it improves the combustion process in a petrol engine but the results suggest it may?
            Here's a site on this topic with loads of nervous skeptics taking forever to try it and then their impressions when they do. I'm up to page 19 and it feels like about 50 have tried it and then commented. Good genuine feedback from people who were expecting very little but gave it a try.
            View topic - Interesting thread about 2 stroke oil in diesel fuel | Australian 4WD Action
            • Originally posted by CardinalSin View Post
              Would help, but the ECU software kicks in a km based regen if it doesn't happen in an "average" timeframe, but you will see maximum regen intervals with good fuel and the right additives, and obviously no inner city driving!
              • Originally posted by Greg Roles View Post
                That wouldn't matter if the regen doesn't generate extra soot each time. If it burns enough extra fuel to account for the difference in the fuel consumption that Amalgam got on his Margaret River trip it would have to add about 5L every regen which is ridiculous of course.
                • Originally posted by kaanage View Post
                  EA888 1.8tsi = direct injection.
                  I didn't notice any reduction in idle noise but it's ridiculously quiet & smooth at idle anyway (from the drivers seat).
                  I've done 4708km with 2-stroke at varying levels between 1000:1 - 500:1. Average consumption has been 6.5L/100.
                  The 4564km without 2SO before that I averaged 6.6L/100km so there's not a lot of difference at face value but there are a heap of other variables too.
                  I will note that on Vortex98, Ultimate98 & Mobil98 with 2SO the consumption is consistantly <6.5L/100 but on V-Power98 + 2SO the consumption is consistantly >6.5L/100.
                  I just filled with V-Power yesterday & didn't add 2SO. I think 2SO & V-Power might not be good buddies.
                  Note that I'm currently using synthetic marine 2SO with the TC-3 spec whereas my initial few tanks were mineral 2SO
                    I can't see why it would reduce friction in the valve guides - it's DI and the fuel doesn't go near them.
                    What it might be doing is slightly altering the 02 readings towards a rich mixture and fooling the sensors into running the engine slightly lean. Similar happens when you run ethanol fuels (even E10) in these engines. The O2 sensors read the mixture as lean because of the oxygen released from the ethanol as a biproduct of combustion and the ECU pumps a bit more fuel in.
                    • Originally posted by brad View Post
                      Neither can I, I wasn't thinking clearly when I said that.
                      If the O2 sensor is leaning the mixture out, would that raise or lower the EGT?
                      Fantastic fuel economy. What made you change from mineral to marine synthetic when that has been the blend that's been widely reported not to use, based on it's combustion properties being less complete than mineral oil and causing problems such as deposits on the injector tips? Someone was using it on a BRZ/86 and noticed increased deposits on the injectors when they pulled them out again as the seals were causing problems. That's just a specific case I can remember but the warning has come from similar cases I would imagine.
                        I assume a leaner mixture would raise EGTs
                        The mineral was the old Stihl / Castrol stuff I had sitting on the shelf. When that ran out I bought whatever was available at Supercheap for <$10 (I had a $10 credit note). All they had was TC-3. We shall see.
                        The type of driving I do has always got me averaging <7L/100 plus I have the official title bestowed on me by Shell of "Australia's Most Economical Driver"
                        • I would also assume it would raise the EGT but apart from one case, all the others have reported it lowers the EGT.
                          If we eliminate that we are left with more complete combustion, which would explain the low soot and other emission levels along with the lower EGT's.
                          I bought that oil from SC too but it's waiting to pamper the chainsaw now, after I decided not to use it. The great price was too much to resist, I remember it well!
                          I'm impressed by the title, well done!
                          I enjoy averaging lower than the official figure from my cars too and the brakes last a long time when you avoid using them.
                            As I don't have an EGT sensor I wouldn't have a clue.
                            The title was nice but the $5k cheque was better.
                              A fair number of diesel owners have them, especially if they tow or up the power. When my Triton 2.5CRD was modified for a while, the intercooler temp would go through the roof when I stomped on it. I hate to think what the EGT was? That had 2SO from 3,000km too.
                              I can imagine how hard everyone tried with that carrot for the taking. It must have been difficult for them when they had to congratulate you, spewing at the same time.
                              • Here's an interesting post on reduced sound levels after adding 2SO.
                                As you might have noticed, i'm halfway though the posts. One point that comes up on a regular basis is the reduction or elimination of smoke from the exhaust, such as "used to see smoke in the headlights behind while accelerating at night, now there's none". Also "how much cleaner the back of the vehicle is since using 2SO". Not exact quotes but the gist of the comments.
                                All of which confirm the reduction of soot levels in those cases and thus the evidence that the DPF will have less particles deposited and therefore a longer life.
                                "Well bugger me sideways I wouldn't have believed it if I didn't see it with my own eyes.
                                I've a 79 Series ute with a 1HD-FTE motor. I'd read all the things people where saying about the things the 2-stroke oil does, I tried it in the Prado and all good. So now I've got the 79series I thought I'd try it in that. But.....I tried to be a little more scientific about it, so I grabbed the sound level meter from work and took some readings. This is what I found.
                                Before addition of 2-stroke oil to fuel, with the sound meter resting on the passenger seat engine at operating temperature, A/C off and engine at idle, with the microphone facing towards the front, a maximum sound pressure level of 74.1dB was recorded.
                                After the addition of Castrol 2T to the fuel load at a ratio of 1:200 and sufficient time and agitation for the fuel load to mix with the same operating conditions a maximum sound power level of 70.6dB was recorded.
                                I only measured the in cab noise because that's the only one that's relevant to the passengers.
                                I was absolutely flabbergasted. 3.5dB lower may not sound like a lot, but I believe and I may be wrong and feel free to correct me, a decrease in 3dB means its half the amount of power. Which is different to sounding half as loud.
                                ...hang on I have to go listen to it again.....
                                Doesn't sound half as loud, but anyhow its a decrease of 3.5dB so it definitely has a measurable difference in the mechanical noise from the engine.
                                Just thought you guys would like to know that.
