As far as EGTs go, for a gasser, leaner is hotter, for a diesel, leaner is cooler. You need fuel to raise EGTs in an oiler.
2 stroke oil (2SO) as an additive to diesel fuel
Thanks GregOriginally posted by Greg Roles View PostAs far as EGTs go, for a gasser, leaner is hotter, for a diesel, leaner is cooler. You need fuel to raise EGTs in an oiler.
As you may have noticed, I'm a real wiz with diesels
Actually, some of them didn't give a toss. We were all driving MKV Golf 1.6 Autos on ULP. The routewas a 200km loop from Rose Hill up into the Blue Mountains & back.Originally posted by CardinalSin View PostI can imagine how hard everyone tried with that carrot for the taking. It must have been difficult for them when they had to congratulate you, spewing at the same time.
I was driving with Darryl Eastlake and an observer (about 260kg of passengers). Daryll did 2/3rds of the driving because he couldn't read a map for love nor money.
His wife was getting cancer treatment that day & he wanted to be there but had committed to the drive so he was getting "paid" a donation to his favourite charity, The Cancer Council if we won. He said to me when we started "I'm not here to waste a day for nothing. We're here to win for my charity." So we gave it a red hot go & used all the tricks we knew and got 3.68L/100km. Next best was 4.6L/100km and the other 4 cars were over 6L/100km.
Happy days!carandimage The place where Off-Topic is On-Topic
Leaner is a possibility then. People have reported more power but few, if any have mentioned less power. I would have thought leaning the mixture wouldn't increase the power unless they are all running too rich which doesn't make much sense, especially in the search for lower emissions.Originally posted by Greg Roles View PostAs far as EGTs go, for a gasser, leaner is hotter, for a diesel, leaner is cooler. You need fuel to raise EGTs in an oiler.
More complete combustion makes more sense when you look at all of the results.
Here's another post where they measured the sound reduction.
6th post down.
"He gave me the green light and said it couldn't hurt anything at a 200:1 ratio so I purchased some Activ T2 yesterday and gave it a crack. I filled the tank and then went home and put the 2stroke oil in, after starting it up it was normal volume for a few seconds and then it went a fair bit quieter.
I don't have a proper SPL meter but I did use a basic one on my phone because I figured it would show if there was an objective difference (even if it wasn't the real dB level), with my driver side window down and the mic pointed out the window it was ~70dB with just diesel and it then went to ~67-68dB with the 2 stroke oil, the Mrs also noted it was quieter without me saying anything."
View topic - Interesting thread about 2 stroke oil in diesel fuel | Australian 4WD Action
One thing that anyone wanting to try 2-stroke oil in their petrol is that it does slightly reduce the octane rating (see the warning here - Octane & 2-Stroke Oil: Mercury 2.0 Liter | COR Boat Racing), although the very low ratio used is unlikely to have a significant effect.
On the plus side, it almost guarantees a slight cetane improvement in diesels
(a US military study on the relationship between octane and cetane - http://www.dtic.mil/cgi-bin/GetTRDoc?AD=AD0779512)Resident grumpy old fart
Interesting. Keep in mind they are talking Motor Octane Number, not Research Octane Number but 20 points decrease in MON is freaking HUGE and more relevant to real life usage than RON (IMO).Originally posted by kaanage View PostOne thing that anyone wanting to try 2-stroke oil in their petrol is that it does slightly reduce the octane rating (see the warning here - Octane & 2-Stroke Oil: Mercury 2.0 Liter | COR Boat Racing), although the very low ratio used is unlikely to have a significant effect.carandimage The place where Off-Topic is On-Topic
They are talking about ratios as high as 24:1 which is 20 times what the petrol guys seem to be running in 4 strokes.
I can't see 2 stroke oil dropping MON without affecting RON (it's possible chemically but I think it would be unlikely) but as you said, MON is more likely to be important anyway in real life engine loadings.Resident grumpy old fart
Also, Brad is using a fully synthetic oil which only reduced the MON by about 10% of the amount the mineral oil changed it by. When you reduce that by the 1/20th of the quantity it becomes insignificant.
The reduction of the MON by 20 at 1:24 for a mineral 2SO is a surprising result that seems unlikely in theory.
Reporting back on the Passat 125TDI.
I am nearing the end of the second tank sans 2SO and I believe that there is more diesel clatter and it seems harder to achieve the same low L/100km on the MDF. My only disclaimer is that current driving is in suburbia not on the highway with the cruise on.
Interesting nonetheless.
