Originally posted by CardinalSin
View Post
Physical signs that it was rich / oversooting were when I pulled out the O2 sensor near the #2 cat and it was quite coated. I burned it all clean with the blow torch I use for putting the toffee crust on a Creme Brulee and then cleaned the inner section where the sensor is with solvent.
At the moment it's like "I'm losing weight" and not knowing if it's because you have cancer or leading a healthy lifestyle.
