Originally posted by CardinalSin
View Post
Diesel fuel additives for modern diesel.
You can't be serious? Calling those who are qualified incl. the engine manufacturers..."the unqualified armchair critics".Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
No, this is a forum and the comments here are from the forum members. Some try out new ideas and post their results while others tend to ridicule them and suggest any favourable results are pure fantasy.Originally posted by Transporter View PostYou can't be serious? Calling those who are qualified incl. the engine manufacturers..."the unqualified armchair critics".
I know the results I have had over the years are real. The engines have been quieter, smoother with better economy[carefully recorded] and the exhaust is cleaner with hardly any smell compared to without 2SO. Others have had the same results.
Those results should be respected as they are genuine, anything less is offensive.
...and the forum members are telling you that there is a lot of official discouragement against using the 2SO as a diesel additive in the DPF equipped cars.Originally posted by CardinalSin View PostNo, this is a forum and the comments here are from the forum members. Some try out new ideas and post their results while others tend to ridicule them and suggest any favourable results are pure fantasy.
please feel free to start a new thread or use the one that I've suggested earlier if you want to keep posting about the 2SO and leave this one for the diesel additives. The 2SO is not a diesel additive, no matter how much research you do.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
2 Stroke Oil - It's what we've been talking about for the last dozen or so posts.Originally posted by Ryeman View PostI referred to 250
Whats this 2SO?
So what is 1:8000?
What is 250?
I'm on tenterhookscarandimage The place where Off-Topic is On-Topic
+ 1 for Penrite DPF in my PD and +1 for Penrite DPF in my CR.Originally posted by Transporter View Post
The Penrite DPF Cleaner contains Cerium and should be a very good choice for the DPF equipped diesels.
As always read the instructions on the bottle.2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
I'm inclined to accept Penrite's products but to be consistent it's the same old question of why when the manufacturers say don't
And
Why is it not in pump diesel if it's beneficial?
Then, do all service divisions add their own unspecified additive?
Why would you include DPF cleaner in diesel when so many diesels don't have a DPF or many that do have a DPF use AdBlue or similar as standard equipment?Originally posted by Ryeman View PostI'm inclined to accept Penrite's products but to be consistent it's the same old question of why when the manufacturers say don't
And
It would just add unnecessary cost which while negligable for a small SUV owner doing 20,000km/pa would be a huge expense for a prime mover operator doing 200,000km/pa.carandimage The place where Off-Topic is On-Topic
Isn't AdBlue for NOx reduction, not soot?
Also, I read on a DPF cleaning additive that it should not be used for vehicles with inbuilt DPF additive injection systems (eg Peugeots). Doesn't apply to VWs but something to keep in mind for some other "modern" diesels.
But Ryeman's question is valid for "smoke killer" and "injector lubricant" additivesResident grumpy old fart
Some additives work best when added into the fuel tank before you put fuel in. The additives added in refinery could be somehow depleted after they were in the underground tanks.Originally posted by Ryeman View PostI'm inclined to accept Penrite's products but to be consistent it's the same old question of why when the manufacturers say don't
And
Using purpose made additives in fuel makes sense, stick to the instructions and your diesel engine will benefit from it. There is more to the diesel additive that just to add a bit more lubrication. A good diesel additive will disperse water contained in the diesel fuel, fight bacteria and will provide additional lubrication as well as clean injectors.
I personally stick with the diesel additives from well established companies and don't gamble with the CR diesel fuel system, there is no need for it.
I thought it was for the DPF but I'm probably wrong.Originally posted by kaanage View PostIsn't AdBlue for NOx reduction, not soot?
But Ryeman's question is valid for "smoke killer" and "injector lubricant" additivescarandimage The place where Off-Topic is On-Topic
Chuck it in and see what happens ya big babies!
Adblue is a catalyst for soot particles, which are always the problem, dropping NOX is dead easy in comparison. It's usually Cerium or Stontium or some other highly toxic substance....basically a metal catalyst to further burn soot ( unburnt and carbon coated fuel ) down further.
DPF cleaners are usually just toluene or some other high hydrocarbon fluid, and without some actual Cerium in them I have to wonder just how much good they really do. Wynns has Cerium in it, but I can only get that from the UK on eBay. Does make the DPF regen in record time though, but does nothing for accumulated load ( ash ).2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
