G-8VXWWTRHPN Diesel fuel additives for modern diesel. - VWWatercooled Australia
    The MK6 DPF will last longer then the MK5's, just the nature of common rail vs PD, and the DPF's themselves are evolving. Fuel Doctor will do stuff all to the DPF directly, but by keeping injectors clean keeps soot to a minimum. Moreys will indeed lower the load on the DPF, as well as lube the fuel pump and injectors themselves, which becomes critical in common rail. Cheap insurance of two vital parts.
      So Greg, should I think about starting the programme on my 2012 103TDI Yeti which has done 18K?
      It was in storage for 2 years (surplus stock) and the kms have almost exclusively country driving and has a DTUK CRD2+ box fitted for most of the distance.
        Consider also Penrite DPF Cleaner.
        Where money is not a problem I use BG244J with a fantastic result in my customer's cars and every 3months in all our diesels. While at every fill up the girls are religiously using Liqui Moly diesel additive, that I pour into a small plastic bottles and store them in the rear door pocket.
          Where do you get the Morey's Diesel Smoke Killer....any auto outlet?
            Repco should have it, but you could probably get it cheaper from some other automotive shops. I get mine from Moreys.
              I like using this one Cleen Diesel - High Performance Diesel Additive
                The key to a healthy fuel system and clean injectors is to use the additive 100% of the time. It's a big task for the "once in 15,000km additive" to clean the injectors in one hit.
                The Penrite DPF Cleaner contains Cerium and should be a very good choice for the DPF equipped diesels.
                As always read the instructions on the bottle.
                  Me too; however it is no longer available for retail sale (straight from the manufacturers mouth!)
                  I have now moved on to Moreys' Diesel Smoke Killer!
                    So now I'm confused.......Penrite OR Morey's OR both for my 22K TDI Yeti?
                    And where to buy at best prices?
                      I've moved the 2 stroke oil as an additive posts to its own thread, so please continue the conversation on the 2 stroke oil as an additive there.
                      Here is the link for your convenience. http://www.vwwatercooled.com/forums/...ing-55494.html
                        Should this thread's title be changed to reflect that it is for diesel specific additives, only? (to prevent any other things like BD and WVGO being introduced)
                        Resident grumpy old fart
                        • #27
                          That's a shame, it's the best diesel additive there is and cheaper than the others mentioned so far. The other thread doesn't mention diesel either.
                          • #28
                            Yeah, in your car owner's opinion.
                            • #29
                              I'll still stick to Morey's — and strangely enough it's cheaper than low ash 2-stroke oil.
                              More per litre, but you use less of it.
                              • #30
                                Well, yes but there are also many other car owners who agree. That's well documented throughout various forums.
                                The opinion of those that actually test the idea, in the real world, is worth more than the unqualified opinions of armchair critics.
