When i say it clicks it clicks once and engages the starter motor but it doesnt turn over at all. The engine was shut down and wouldnt start again.
9. when i say i hooked the merc battery up, i pulled it out of the merc and put it in the golf then put a jumper cable on it.
10. Transporter when i put it into forth and rocked it I watched the timing belt to see it it would move. Even though it was really hard to move the car it did turn over the engine so i dont think the pistons have seized in the bores. Is this the same result you wanted to see with turning over the engine at the crank pulley?
10. I tried what transporter said and turned on the high beams and had no voltage drop..
11. gldgti i ran a multimeter over the injector pump selenoid and it showed 12.5V with the key off. when i went to turn the ignition on it would drop to 1.1v.
GLDGTI i didnt take off the timing cover as i think that is a bit over my head and if it was broken/ mis adjusted i couldnt fix it myself anyway.
Unless you guys think it is the injector pump selenoid does anyone have a recomendation of where to take the the Golf where they would understand diesels. I am located in Aspendale gardens and i know of The VW place in Dandenong and thats it. Im open to suggestions.
Once again thank you all for your time and effort.
Mark
Mark
