Strange that they specifically tell you to not use additives but then suggest an additive, so for my 2012 103TDI anyone know what they recommend?
Diesel additives..... Fyrex Ci ?
Volkswagen do not recommend using a particular fuel additive product, beyond those already added by the fuel companies, if the fuel meets European standards (refer to EN 228 for petrol, EN 590 for diesel).
Volkswagen prohibit the use of fuels or fuel additives with metallic content. Such products would interfere with the operation of the engine and its emissions devices, esp. the diesel particulate filter (DPF), and may eventually cause damage.
Volkswagen prohibit the use of diesel fuel additives ("flow-improvers") which reduce fuel lubricity. Lack of diesel fuel lubricity can cause damage to fuel injection equipment. Adding petrol to diesel has much the same effect.
Apart from that, Volkswagen does not prohibit the use of fuel additives outright, so the owner is free to use whichever aftermarket or off-the-shelf products they wish, but at the same time, that does not mean taking a carte blanche attitude to what one pours down the vehicle's fuel tank.
There is also the true cost/benefit analysis to consider.
As always, my advice on such matters is to do your research thoroughly.Last edited by Diesel_vert; 23-04-2014, 03:32 PM.
VAG specifies diesel with cetane 51 for DPF fitted diesels. No diesel fuel in our market meets that. Often they will but the Australian Standard only says CN46. It seems highly likely that extra soot caused by low cetane fuels contributes to DPF failures. BP Ultimate once did have a cetane improver and had a specified minimum cetane over 51, typically 55.
Transporter recommended Morey's Diesel Smoke Killer as a cetane improving additive. I have been using that. Still to get data out of the computer after nearly 30,000k using it in the Yeti. Morey's also has an algicide, which I think is also a good idea with diesel.2015 Polo Comfortline 6M + Driving Comfort Package
2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
(2008 MY09 Polo 9N3 TDI retired hurt hail damage)
Yes, that's minimum CN51 to be precise.
There is only one reason why VW was/is against the fuel additives. It's because there are many additives that don't have to be suitable for the TDI or TSI engines, besides, one can't ever know what kind of additive comes in the shops tomorrow. Basically, it's beyond VAG control. However, the reputable workshop will most likely use good quality additives.
So, stick with the well known established brands and you can always call to confirm if their product is suitable for your engine, if you aren't sure.
From my experience, I don't recall that I would have to attend the car which was using fuel additives on a regular basis and had a fuel related problem.
But, I do recall many that never used the fuel additive and had a problem with the fuel system.
IMO, there is far less (if any) fuel system faults which could be blamed on the additive, than faults that were caused by poor quality fuel, water in diesel and fuel system components prematurely worn out.
Regular use will extend the life of the components and maintain good fuel economy for much longer, so the cost of the additive will repay itself back many times.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by bluey View PostVAG specifies diesel with cetane 51 for DPF fitted diesels. No diesel fuel in our market meets that. Often they will but the Australian Standard only says CN46.
EN 590 specifies a minimum cetane index of 46, and a minimum cetane number of 51.
Australian fuel standards also specifies a minimum cetane index of 46, but does not specify a minimum cetane number.
In practice, the final product that comes out of Australian terminals has a typical cetane index varying from 49 to 52, according to my own collation of various bits of information on the internet. Depending on the crude oil source and the ASTM method (previous D976 or current D4737) used to calculate the cetane index, the actual cetane number would either be close to, or exceed, the cetane index, which bodes well for everyone.
Rather than cetane, the progressive removal of sulfur in diesel fuel is probably the most significant factor that has contributed to the reduction in smoke emissions and soot (i.e. particulate matter), which of course, what facilitates the introduction of DPFs onto the wider market in the first place. Current sulfur levels in diesel fuel since 2009 is at less than 10 ppm (in line with Europe), down from 50 ppm since 2006, and 500 ppm since 2003.
Originally posted by bluey View PostIt seems highly likely that extra soot caused by low cetane fuels contributes to DPF failures.
The difference between the cetane number of European and Australian diesel is not so significant as to generate high DPF "failure" rates in this country.
In any case, it is not soot that permanently disables the DPF - it is ash.
Soot can be burnt off during the regeneration process. Metallic compounds, of which the primary source is engine lubricant, reduces to ash during the regeneration process, which cannot be burnt off and will eventually clog up the DPF (hence the need to use low-SAPS or mid-SAPS engine oils, as opposed to full-SAPS).
In addition, UK and European motorists are quite familiar with DPF issues similiar to those experienced by Australian motorists, so it is not a phenomenon unique to this country, irrespective of marque.
Further, it is not inconceivable that faulty parts and componentry have been misdiagnosed for DPF issues. For instance, the G450 sensor in VAG cars have been known to fail, preventing the DPF from operating as intended.
Originally posted by bluey View PostStill to get data out of the computer after nearly 30,000k using it in the Yeti. Morey's also has an algicide, which I think is also a good idea with diesel.Last edited by Diesel_vert; 24-04-2014, 02:02 AM.
Caltex told me "typical" diesel cetane index here is ">50".
I suspect the question will be answered in a court one day, when a car-loving lawyer has a DPF failure that they don't want to pay to fix. The technical and legal question is - if a manufacturer supplies a product that requires fuel of a certain specification and the fuel widely available clearly does not meet the specification and may well contribute to damage, who should wear the cost?
The simple business deal is that our diesel needs a cetane improver to meet the specification. Car manufacturers could make sure at least one diesel product has a cetane improver and then that would become the recommended fuel.2015 Polo Comfortline 6M + Driving Comfort Package
Fortuitous that this is top of the forum discussion list, as I was in the local autoparts joint yesterday on an unrelated errand and saw diesel fuel additives and read the labels - almost went for the wallet but decided to check here before adding something to the 103 TDI Skoda Scout, which has not missed a beat since I bought it with 47k on the clock, now 73k.
And of course, all manufacturers recommend you run this stuff in every tank. I use Caltex Vortex from the Woolies joint or BP. Have managed to avoid unknowns for the most part, but eventually a trip into the distant reaches will necessitate filling with whatever is available.
What pricked my interest the most was Penrite DPF Cleaner that is added to the tank - claims to lower soot levels, enhance regen and do so at lower temps (odd, as I thought high temp was required to burn off soot?). Also considering something to ward off the evil fungus. As with others on here, my main concern is adding stuff to a modern hi-tech diesel - huge diff in design parameters compared to the days of the Commer knockers and the belching, crawling semis I remember clawing their way up every incline on the highways we drove on holidays as a kid.
Anyone familiar with the Penrite DPF cleaner stuff? As for general treatment, it's hard to know which to go for where fungus-evasion is the primary motive. What should I avoid? I don't need more performance - more than happy with the beast, especially since an Oettinger remap.
Curious product. MSDS says 60% light petroleum distillates. <4% nasty hydrocarbons. 35% "other stuff". no mention of algicide.
Transporter recommended Morey's Diesel smoke killer and has elsewhere reported on his long-term data collection from vehicles running with that. Have been using Morey's DSK for a few years. Seemed to make a visible difference to soot out the tailpipe (seen in other cars' headlights at night) on non-DPF Polo. Seems to make engine a bit quieter as expected with a higher cetane fuel.2015 Polo Comfortline 6M + Driving Comfort Package
Originally posted by Skooter View Post?...........
.......... compared to the days of the Commer knockers and the belching, crawling semis I remember clawing their way up every incline on the highways we drove on holidays as a kid...........
Originally posted by bluey View PostCaltex told me "typical" diesel cetane index here is ">50".
In practice, however, that does not mean Australian diesel fuel can never comply with the requirements of EN 590. Given the standard of diesel that is coming out of our fuel terminals (based on typical cetane index, lubricity rating and sulfur content values), it does not necessarily follow that the regular use of such fuel would create issues so significant as to cause damage to the FIE, DPF or the engine itself.
A DPF should function as intended so long as nothing prevents the regeneration process from taking place (which can easily occur under certain operating conditions, which owners need to be made aware of) and the amount of ash is such that exhaust flow is not significantly hampered.
That's not to say the cetane number cannot be increased thorugh user intervention (by adding a fuel additive containing cetane improvers), but the correlation between the cetane index of automotive diesel fuel in Australia and genuine DPF faults, is not strong, IMO.Last edited by Diesel_vert; 24-04-2014, 04:33 PM.
Also keep in mind that the DPF doesn't infinitive number of regenerations, which means if you use lesser quality fuel. Very simply said, it will regenerate more often. For example it could regenerate every 300km-500km instead of every 1000km, and also the regeneration time could be longer when using lesser quality fuel.
Penrite DPF cleaner should help to reduce the soot amount in the DPF, which should result in shorter regeneration times, hence extending the life of the DPF even further.
Originally posted by Skooter View PostWhat pricked my interest the most was Penrite DPF Cleaner that is added to the tank - claims to lower soot levels, enhance regen and do so at lower temps (odd, as I thought high temp was required to burn off soot?)
You can alter between Penrite DPF Cleaner and Moreys DSK.
Just a reminder that our diesel was so bad before year 2000 that not many manufacturers bothered with bringing their diesel engines to our country. The allowed sulphur level in our diesel fuel was much higher than in EU diesel fuel, it was probably as good as the Indonesian fuels.
Sulphur in diesel:
Year
1999 - 2002 average was 1300ppm and it could be as high as 6000ppm
2002 - 2005 500ppm
1.1.2006 - 2008 10ppm
1.1. 2009 10ppm
I would also question the quality of our engine oils used in VAG engines up to 2005, but I don't want to open the can of worms. Just a note that, it would be handy to know, how many dealerships in Australia can/or is using local engine oils in TDI today and why they have to use imported oil from Europe? I think I know the answer to it.Last edited by Transporter; 25-04-2014, 11:43 PM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Ryeman View PostI'm wondering if we will actually get higher quality diesel when it's shipped from Singapore as opposed to the fuel from our disappearing uneconomic refineries.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Transporter View PostAlso keep in mind that the DPF doesn't infinitive number of regenerations, which means if you use lesser quality fuel. Very simply said, it will regenerate more often. For example it could regenerate every 300km-500km instead of every 1000km, and also the regeneration time could be longer when using lesser quality fuel.
Originally posted by Transporter View PostJust a reminder that our diesel was so bad before year 2000 that not many manufacturers bothered with bringing their diesel engines to our country. The allowed sulphur level in our diesel fuel was much higher than in EU diesel fuel, it was probably as good as the Indonesian fuels.
The primary reason why diesel engined passenger cars weren't popular here until relatively recently is that the market for these vehicles was tiny, owing to a number of social and economic factors (very low petrol prices, little focus on fuel economy, dominance of Australian and Japanese marques, high import tariffs, uncompetitive European car prices, less sophisticated diesel engine technology, public perception of diesel, etc). Seems so long ago now, lol.
Even in Europe, the market share of diesel passenger cars only really took off from the late 90s/early 2000s (20%) to almost half (50%) by the mid 2000s, where it remains to this day (give or take).
Marques which have consistently made diesel passenger cars available here (off the top of my head) include Mercedes-Benz and Peugeot, who have being importing them for decades, but were more popular in regional or rural areas.
Originally posted by Ryeman View PostThe bottom line is they closed because they couldn't justify the cost of keeping up with fuel standards eg euro 6 and beyond so its a moot point realy.
