Hey there, would the Castrol Edge 5w-40 A3/B4 be a good option for the ea113 motor ? Mine is stage 2 tuned, seen some others recommend this online. Just did an oil change with the vw recommended 5w-30. Cheers
Best oil for stage 2 scirocco?
I tend to use a 5w40 Liqui Moly, seems to reduce oil consumption.
That Castrol oil you have pictured meets the VW502/505 oil spec, so its ok to use in the EA113.
As far as I know there are no 5w-40 oils that meet the newer spec VW504/507, so you have to use the older spec which is VW502/505. I used to run 5w-40 in my old Mk6 GTI as it used to drink a little bit of oil, and moving from a 5w-30 to a 5w-40 seemed to slow down the oil consumption a bit, plus the 5w-40 oil is generally a bit cheaper so its a win win.
I used to use Penrite Enviro+ 5w-40 because it was readily and easily accessable at Repco/Supercheap etc and also regularly on sale so I would buy a couple of bottles when they were on sale: Penrite Enviro+ Engine Oil - 5W-40 5 Litre | Supercheap Auto
Edit - just got an email from Automotive Superstore and these ones are on special.
Nulon 5w-40
Penrite 5w-40Last edited by Lucas_R; 29-07-2024, 01:03 PM.
