G-8VXWWTRHPN :: ECS Tuning :: VW MK4 R32 ECS Billet Aluminum Water Pipe - Click Here !!! - VWWatercooled Australia
  • :: ECS Tuning :: VW MK4 R32 ECS Billet Aluminum Water Pipe - Click Here !!!
    The OEM water pipe is made of plastic, like many other components in your cooling system. This plastic becomes brittle over time and exposure to constant temperature change.
    Instead of installing another plastic piece that is bound to fail, ECS engineered a permanent solution; Our Billet Aluminum Water Pipe. We started with the OEM piece to ensure we get all the critical dimensions just right.
    Machined from 6061 aluminum for a strong yet lightweight pipe and anodized to protect against corrosion. This is designed to be the last water pipe you'll ever need to replace.
    http://www.ecstuning.com
