Headunit installation - Mk5 Golf
  • Headunit installation - Mk5 Golf
    Hi all just got myself a MK5 GTI and wondering if anyone here has experience in or can provide some info on installing a new headunit.
    I'm looking at the Alpine iLX-007E because of it's apple carplay integration.
    Just wondering if anyone knows how it goes with the steering wheel controls, canbus battery drain problems and where to get a fascia surround for it?
    Thanks in advance!
    I did this for both my Jettas
    From nexxiamail.co.uk
    2 x CT24VW03 - Volkswagen Radio Fascia Adapter Jetta Passat Polo Touran - 7.91 each, 15.82 total
    2 x CTSVW002.2 - CTSVW002.2 Volkswagen Steering Control Adapter Canbus - 33.29 each, 66.58 total
    2 x CTSONYLEAD - Connects2 Sony Patch Lead - 3.29 each, 6.58 total
    1 x PPX - Postage & Packing - 21.95 each, 21.95 total
    Net Amount: 110.93 GBP
    On install I realised I also needed an ISO to Sony specific plug
    Supercheapauto
    HARNESS ISO TO SONY APP8SP4 - Supercheap Auto
    That should be a good start, adjust for Alpine / Pioneer etc
    That all works perfectly no cutting anything.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
      Have you looked at maybe buying an RCD 330 instead?
      2010 Platinum Grey VW Jetta 147 Highline APR Stage 1 Tune Carbonio CAI Team Dynamics Pro Race 1.2 rims
      2013 Candy White Skoda Ambition Plus 103TSI with Tech Pack
        Thanks JustCruisn. Guess that connects2 brang stuff u mentioned is the way to go.
        Yes Shanrus I have looked at the oem options but am figuring that an aftermarket unit like the alpine will sound and operate better. Correct me if I'm wrong. Plus will also be cheaper not having to purchase a bluetooth module.
          From all accounts the RCD330 is a brilliant piece of kit, well worth the upgrade.
            Yep, heavily leaning towards the rcd330 option now. Been doing some more reading and looks like it will integrate nicely.
            Anyone know where to get a canbus gateway recoded in sydney? That seems to be the only issue standing in the way.
              You can pick up a canbus gateway or emulator off ebay - probably easier/cheaper?
              Past - 2006 Mk5 R32, 2012 R56 Mini Cooper S
              Current - 2010 Mk6 GTi - Build Thread
                Anyone know if a rcd330 would work in a R36 with Dynaudio?
                  Not the same way as an rns or rcd can switch to line level balanced output.
                  You'd have to use a line out converter as rcd330 is speaker level unbalanced output only.
                  Sent from my HTC 10 using Tapatalk
                    I think there's a way to get a line level signal without a converter, but it involves some soldering to the back of the unit, giving you (i believe) FL/FR/RL/RR channels . You'd still have to find a way to splice that signal into the Dynaudio harness, but i spose the 330+ features set might be attractive enough to warrant such an install
                    2004 MK4 R32 - Reflex Silver - KW V3 - AdvanSport V105 - Colour Matched RCN210
                    2012 up! 3Door - Tornado Red - More details soon…
                      Originally posted by greyhamism View Post
                      I think there's a way to get a line level signal without a converter, but it involves some soldering to the back of the unit, giving you (i believe) FL/FR/RL/RR channels.
                      Do you have any more details on that? I have a mate with a (new to him) Polo considering the RCD330+ and RCA outputs would be very handy to have since he also wants an amp/speaker upgrade. (and line converters tend to suck).
                        It takes a bit of piecing together given the source ive found is in russian, but here's that page ive been following : RCD330g Plus Desay - ?????????? - 4PDA
                        Heres and example of a mod done (again in russian :/ ) with a home made amp that you probably wouldn't need if you where hooking it up to an amp : rcd 330 desay линейный выход — бортжурнал Skoda Octavia 1.8 apr st 1+ (1.2 bar) 2012 года на DRIVE2
                        Hope this helps
