Map updates - Discover Pro
  • #31
    Thanks a lot karmold. It worked!
    I also made a couple of other changes like enabling AM radio. Not that I listen to AM much but can be useful when in remote areas and for the news
    Originally posted by kamold View Post
    I guess they really wanted DAB.
    Does that mean my particular infotainment unit has DAB+ radio? Or just the ability to work with a VW DAB+ add on module? I could see some option in the 5F module on the OBD11 for DAB but thought it was referring to something else (i.e. the DAB thing in the Green Menu)
    I know this is slightly off topic but are there any settings in 5F that affect radio station preset memory?
    • #32
      It should have a black dab connector on the back.
      Plug in a dab antenna and you have dab as long as it's not disabled in coding.
      • #33
        I have downloaded the 23GB rest of the world package but cant see how to delete the countries I dont want
        Firstly I downloaded the file to my computer. Then I decided to do it using Discover care to d/load and install on and Sd card
        Have done it but dont really want all the countries on it.
        A how to so that I dont get them all would be nice thanks
        • #34
          Hi everyone,
          Quick question. I am shipping my 2017 Tiggy from Sydney to Auckland next month (new job)
          Does anyone know if DAP and Sat nav will work, and if not, what I can do about it?
          Thanks,
          Steve
          • #35
            Satnavs should work anywhere but you will need a NZ map in it or you will only have the base map I guess
            • #36
              I have just returned form a 2000km trip and have to admit I don't think the nav system is good enough to even bother with an update. I was lucky or perceptive enough to having paper maps with me to get out of trouble a few times on the trip.
              • #37
                Thanks dude. Appreciate the advice
                • #38
                  Originally posted by Monksta_no1 View Post
                  Hi everyone,
                  Thanks,
                  Steve
                  the AU and NZ maps are both the same MRM (rest of the world) maps - so ur navigation maps will continue to work here.
                  • #39
                    New version available on the site, dated 1 Oct 2018.
                    • #40
                      If I've successfully downloaded the new maps to a SD Card and my head unit can recognise it but indicates (in the SWDL menu) that the new map version is 'N/A', what could be stopping the upgrade from proceeding?
                      • #41
                        I downloaded the recent 23.2gb file to a 32gb card and the car updated. At 18% it failed. The system rebooted and attempted to co tongue, but failed without progressing. I cancelled it and the map is saying aus/nz are 2019, but the rest of the date says 2017/2018 and I don’t know if the actual firmware/software of the headunit has updated.
                        I believe the maps were successful, as navigating around the recent south road works, near port Rd(Adelaide) the map is showing the new layout, whereas pre-update attempt, it wasn’t.
                        As a completionist, though, I’d like to have everything up to date.
                        Any tips are welcome!
                        Cheers.
                        • #42
                          the P76 (ROW 2019) installed successfully in mine, and the speed signs are still showing as they were before.
                          all good
                          • #43
                            I have been able to successfully update the Sat Nav also to P76 ROW 2019.
                            The above download is now available on the ŠKODA update portal; Update portal
                            • #44
                              Yes, works well. Updated the maps on our brand new Passat Wolfsburg today.
                              Maps on the car were at 65! Updated to 76 now.
                              I just downloaded the ROW data and loaded onto USB (exFAT) and it worked fine - took 50min. Might try a Class 10 SD card next time as I think it might be a little quicker.
                              2018 Passat Alltrack Wolfsburg
                              2017 Polo (Sportspack)
                              • #45
                                Originally posted by Delewin View Post
                                Thank you Kamold and doc_777,
                                I downloaded the full 27Gb, but it complained when I wanted to install it to a 64Gb SDXC card. So I found an old 32Gb SD card and installed the Australia / New Zealand maps file only. Then I took the SD card in stuck it in SD1 slot and updated my Discover Pro2 maps. That took approx. 5 minutes in car. The map is working fine.
                                Thank you again.
                                David
                                Are you able to give some details on which files you kept to enable updating AU/NZ maps only? I removed all files that did not refer to AUS or NZ but it says it cannot update as data is missing! My car also has the Discover Pro 2 radio.
