Map updates - Discover Pro
    Hi LimestoneR7
    When I updated the maps again this year it took much longer as I went via the non Europe / other maps and it took about 45 minutes to finish the update. I suggest you buy the cheapest 32Gb sd card you can get and try it. Speed is not an issue. Success is.
    Good luck.
    David
    Sent from my SM-N950F using Tapatalk
    Ordered: 2017 build date Tiguan 162 TSI Highline with DAP in Tungsten Silver and rear luggage tray. ETA: late April / Early May. I did not have to wait. I took delivery on 11 March 2017.
      Thanks Delewin. Unfortunately no luck with a brand new 32GB card.
      I didn't format it, allowed the VW app to copy everything across with no error messages, and even remembered by to use the copy protect switch as instructed.
      Honestly, if the infotainment unit wasn't so integrated with the car both physically and interface wise I would just ditch it. It sounds very average, wont work with an iPod and even the FM stations presets wont save after if turn it off (I have a separate thread about that..).
      I know that soundwise things can be improved with a complete Dynaudio setup that can be retrofitted but that costs a lot to buy and have fitted, but if I can't even update the maps or install POI's myself or have radio stations presets saved, I'm not sure I would bother.
        An update. I've found out that to allow maps to be updated, my MIB1 unit needs to be removed and sent away to have a firmware upgrade at great expense. Its so expensive that to get a MIB2 unit wouldnt cost that much more, if you exclude installation. So I more or less have a brick that cannot be updated.
        If I knew this would happen I would have been better off stretching for a new new or demonstrator Grid.
          Hi LimestoneR7
          That proverbially s#cks.
          We will all hit a brick wall sometime in the future.
          My MY17 Tiguan has lots of components that have the ability to be very smart, but in Volkswagen Australia's wisdom they have deliberately chosen not to import the feature as active preferring to activate it in a later release.
          That is equally very frustrating.
          All the best
          David
            Noticed the VW map update site now has maps dated 3rd April 18 for Discover and 25th April 18 for Discover Pro.
            Volkswagen Map & Softwareupdates
Name:	Maps VW April 2018.jpg
            Discover media MIB2 (Golf 7)
            Flipper Dog
            Now - T-Roc R, Audi Q5
              I ended up figuring out how to update my maps to the 2018 maps that came out early this year, by using the service menu (SWDL option)
              However today I downloaded the more recent 2018 and I am not able to update, either by the service menu or the conventional method.
              Maybe I need a newer firmware or something?
                You either need a new firmware or someone who can check your settings with VCDS or OBDeleven and enable few locked options.
                I have the same problem as you. Well, partially, as my "brand new" (demonstrator) Tiguan came with an official VW SD card in slot 1 and I was able to update the latest map (1010) by downloading it separately and copying it onto the SD card.
                However I cannot add POIs. I have the same issue like you. I followed the instructions but my Discover unit says I can add POIS with software upgrade and does not see the POIs on the SD card. Odd.
                I asked someone to have a look at my VCDS settings and enable few things, that might help. Maybe you should do the same.
                MY18 VW Tiguan Comfortline
                  I've recently bought a OBD11 but I'm completely unable to access the infotainment unit to activate Traffic Notices and other stuff. Another forum member had advised it is most likely that my retrofitted MIB1 unit was hacked at the time of installation so that it doesn't trip the VW component protection system.
                  It can be fixed but basically I'd (or really some one who knows what they are doing) have to figure how the infotainment unit was hacked, reverse that if possible and have the unit reinstalled "properly" by a dealer so that the retrofitted unit is registered, seen as not stolen and linked to my VIN. Alternatively I can dispose of the infotainment unit, acquire another one and have that one properly installed from scratch. Either way including installation etc will cost a fair bit of money. If I was going to do all that I may as well sell the car and get a near new R Grid. But I'll just have to live with it. I can supplement any limitations with the GPS with my smartphone.
                  From what I've been told, if the Obd11 can't read my infotainment unit, VCDS won't either, for the same reason as explained above.. Happy to be proven this is wrong though
                  Incidently I can now load POIs. It was simply a case of copying the MIB STD directory only to the SD or usb drives. Instructions on this forum and elsewhere had said we copy from a different directory but that may work for MIB2 units only.
                  In any case I don't get a warning sound for the speed camera POIs which was the whole point of the exercise so it's basically useless.....
                    Are you saying that on the SD card under the PersonalPOI directory you have only the MIB2TSD directory, nothing else? Or you only have the MIB2TSD directory, nothing else?
                      Need more information.
                      It's highly unlikely that an mib1 would be hacked as there would be no point.
                      Mib2 are modified to be installed in place of mib1 systems.
                      Even then they can be accessed via diagnostics. If it's a discover pro then you need to go into the GEM green engineering menu, disable dab, enable diagnostics then reboot.
                      And vcds can access a unit by can address (5f) for infotainment manually where obd11 needs to be able to see it from the canbus gateway installation list.
                        I only had the sub directory and the single file that are within the MIB2TSD directory, and nothing else, on the card.
                        • #27
                          What information would you need? I was advised on another forum that it was likely (but not a certainty) that my MIB1 was hacked, nothing more or less, given that the 5f component group on my Obd11 was inaccessible.
                          As my car is a MY2015 R it originally had a Discover Media unit with a smaller screen and the GPS ran off a SD card.
                          Anyway if I go into the engineering menu and make the changes you suggest, would it be then likely that the Obd11 can then access the unit? And if so do I then have to reverse the changes in the engineering menu afterwards?
                          • #28
                            What is the part number of the unit?
                            • #29
                              Device part number is 5E0035020C
                              Hardware is H42
                              Software is 0389
                              • #30
                                OK that is a Skoda Columbus part number. It's the same as a Discover Pro MIB1...I guess they really wanted DAB.
                                So you should be able to enable diagnostics by going into the GEM, disabling DAB and enable diagnostics for next 5 reboots.
                                Once you've accessed it via diagnostics you can enable DAB again and it won't be contactable again.
