Hi all,
Just picked up a 132 Tiguan for the folks. Mum has found that the Bluetooth on her iPhone can only play songs through Bluetooth but cannot change songs or pause etc from the multifunction steering wheel. Song name doesn't show on the mfd or head unit either, not sure if it's supposed to? Phone calls can be answered though.
Decided to try the MDI which doesn't work at all, it charges the phone but says accessory is not supported (iPhone) and the popup stays there for at least 10-20 presses before it goes away, which is weird.
I did a bit of googling and found other people have this problem as well. Is this due to the phone or the head unit? Or even MDI/Bluetooth?
Is there a way this can be fixed? So songs can be changed via the steering wheel or head unit so the phone can just not be touched. Would be good if the MDI worked in that regard too.
If so, would an RCD510 be the answer? As there is no need for GPS. If I were to pick up an RCD510 is it just a straight swap? No issues of can bus and battery drain?
