Want to pop out my he'd unit to figure out if its a power drain but will also need to change the USB lead for a new iPhone 5, so how do I get it out? Pics below
Ta
2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
What he said, usually there is a release tab about 5cm from the face and a couple of metal release tools that come with the HU
If the tabs need to go down the side a bamboo kebab skewer or length of coathanger down the sides. PM me if you are still stuck.
Al..
Al..
By the look of that unit it needs flat removers The pin remove units are usually built in models and have two holes on each side.
Just took one out of a Mazda like that and it didnt look like this one Would say definitely those brass colored bits are the bits to move to get it out That is a unit that has a frame around it that is kept in with tabs behind the dash and usually the clips are screwed into the unit and the tabs lock into the outside frame so pushing them in against the head unit allows it to slide out
Its definitely not an original fitting
