Auto-Polar FIS+ Advanced - Complete Guide
! Does not mean not!
One is requested the other is actual.
With exhaust you have to compare with VCDS and what is labelled for your ecu code. Other wise have an external temp gauge to compare it with. Post your engine code so someone else with same ecu can compare your temps.
I know I have a few egt and cat temps that don't seem correct and can only put it down to mixed up labeling of the temp due to having a uncommon ecu - something I have to verify with VCDS.
					Originally posted by Ferni
									View Post
