Auto-Polar FIS+ Advanced - Complete Guide
  • Auto-Polar FIS+ Advanced - Complete Guide
    OK so there's bits of info all over the place about the AutoPolar FIS+ Advanced so I'm going to consolidate all the important information in the first few posts of this thread with general discussion after.
    If you don't know what the Autopolar FIS+ Advanced is or what it does then here's a link to a video which shows a number of features of the device:
    Basically it's a box which sits next to your CANBUS gateway unit and adds extra diagnostic information/features into your MFD. Further details on FIS+ and it's features is available here: What is Polar FIS+ Advanced?
    List of campatible makes/models is as follows:
    Golf - > Red FIS /MFD
    Golf -> White FIS/MFD
    Golf Plus -> Red FIS/MFD
    Golf Plus -> White FIS/MFD
    Eos -> Red FIS/MFD
    Eos -> White FIS/MFD
    Scirocco-> Red FIS/MFD
    Scirocco -> White FIS/MFD
    Jetta -> Red FIS/MFD
    Jetta -> White FIS/MFD
    Passat -> Red FIS/MFD
    Passat -> White FIS/MFD
    Passat -> Color FIS/MFD
    Passat CC-> Red FIS/MFD
    Passat CC -> White FIS/MFD
    Passat CC -> Color FIS/MFD
    Touran -> Red FIS/MFD
    Touran -> White FIS/MFD
    Tiguan -> Red FIS/MFD
    Tiguan -> White FIS/MFD
    Sharan -> White FIS/MFD[/QUOTE]
    Skoda Octavia -> Red FIS/MFD
    Skoda Octavia -> White FIS/MFD
    Skoda SuperB II - > White FIS/MFD
    Skoda Yeti -> White FIS/MFD
    Skoda New Fabia -> White FIS/MFD
    Skoda Roomster -> White FIS/MFD
    The NEW Skoda Rapid -> White FIS/MFD
    Seat Leon -> Red FIS/MFD
    Seat Leon -> White FIS/MFD
    Seat Alhambra -> White FIS/MFD
    Seat Altea -> Red FIS/MFD
    Seat Altea -> White FIS/MFD
    Seat Altea XL -> Red FIS/MFD
    Seat Altea Xl -> White FIS/MFD
    Seat Altea FreeTrack -> White FIS/MFD
    The NEW Seat Toledo-> White FIS/MFD
    A complete list of all parameters supported is here: Complete Parameter List
    A list of all functions that the FIS+ Advanced supports is here: Complete List of Features
    Links to Installation threads for each model (for overseas visitors please note these are all Australian delivered RHD models. CANBUS gateway can be in different locations depending on LHD/RHD and model):
    Golf Mk6 (installation from engine bay)
    Golf Mk6 (installation from cabin)
    Golf MkV
    Tiguan
    Jetta MkV
    Passat
    Scirocco
    EOS
    Skoda Octavia
    Links to some more detailed information on some features:
    Boost Pressure - Detailed Info
    Mirror Dipping - Instructions
    Bluetooth Emulation for Red MFD (compatibility for latest model BT units)
    Product Support:
    Auto-Polar Forum
    User Manuals
    FAQs and Video Database
    Firmware Updates
    If there's additional information that you've found useful please let me know and I'll look to add it in.
    - Tigger73's 125TSI Build
    Write-up courtesy of the_hawk
    Originally posted by the_hawk
    It all started with this thread and the idea of an inbuilt digital boot gauge.
    Essentially it's talking about the AutoPolar FIS products (I warn you that if you click this link you will want one, consider yourself warned):
    Autopolar Official Web site
    Now the install instructions looked pretty straight forward, drop a cover panel above the pedals and plug in the module... simple enough right... NOPE. Those instructions are designed for a LHD car not RHD, it's also not a 118TSI so I'm not sure if it's different on the GTI, but here we are). EDIT: Confirmed that GTI is in the same place, looks like it's a RHD thing then and everyone will be stuck with this process.
    So after removing the knee air page, the air vents above the pedals and the panel on the drivers side I've discovered that the CANBUS plug I was looking for was not anywhere near either of those locations... in fact you have to access it from the engine bay.
    It turns out the module and the plug I was looking for is buried right up just behind the rain tray. Luckily I have had to access this panel before so was somewhat prepared for what came next.
    My total time end to end including some testing and a lot of screwing around was somewhere between two and three hours. The real time should be something like 1.5 Hours since you will know what you're doing.
    NOTE: Before I started taking photo's I had actually pulled everything apart so these photos were taken putting everything back together and will be shown in reverse order to show you how to pull it all apart.
    So let me start.
    It all started when the FedEX man delivered this this afternoon:
    They say you should plug it into your computer with the supplied USB cable and update it's firmware, especially if you have a vehicle with a white display as it needs to be updated before it will work with the newer cars. It says it only supports Windows with IE7+. Firing up my XP Machine and going to their website saw the upgrade done pretty easily. Sorry I didn't grab any screen shots of this bit.
    Read the instructions, it's worth checking the stock location mentioned in here because that would make install more like 15 minutes. If you can't see the plug they are talking about in about 5 minutes it's probably safe to say it's in the same location as mine.
    NOTE: If a GTI owner can confirm if the plug is in the same place as mine I will remove this step.
    Start by opening the bonnet:
    You need to remove the wipers, rain tray and wiper motor.
    Remove the plastic covers on the wiper assembly with a flat bladed screw driver, be careful not to mark them up.
    Remove the nuts holding the wipers in and the wipers themselves:
    Then pull the rubber along the front of the tray gently off:
    And the foam pieces on each side. Note that there is a cable clipped to the drivers side as pictured, unclip that as your next step is to remove the plastic tray.
    The plastic tray has a lip which clips into a grove along the bottom of the window. Gentle pull up and it should come loose. It does take a little force but it will come loose:
    You will have to bend it slightly to remove it from between the bonnet hinges.
    (again make sure you have unclipped the wire on the drivers side).
    Next you want to remove the wiper motor assembly itself. Two torx screws and it will come loose. It takes a little angling to get it out of it's hole, but it should come free easily.
    Now under that wiper you should see a neat little plastic panel. (Ignore the rubber pipe in mine... like I said, I have been here before).
    Three nuts and the panel lifts out to reveal a bunch of wires and a little plastic box:
    It's this box with the red plug you want!
    It's at this point I remembered they recommend disconnecting the battery before doing any more work... so do that.
    It's also about now that I realised that if I was going to mount this box in this location that any future upgrades might just be real PITA. To get around this I have permanently attached the supplied USB cord and run it down into the space behind that little cubby on the right of the steering wheel... that space is getting rather full for me...
    A couple of cable ties to neaten it up and it's there whenever I need to do a firmware upgrade. (of course this is only useful if you have a laptop).
    Back to the engine bay and it's simply a matter of plugging in the cables and installing the box into the space behind that panel.
    You can now re-connect the battery and test it all works including a test drive. After that it's simply the reverse order to get everything installed back how it should be.
    In my case I don't have an "additional" menu item, rather this new menu has taken over the Phone menu... BUT don't worry, pressing the phone button the multifunction steering wheel bring up the old menu as does making or receiving a phone call.
    I haven't had a big play with it yet, but I do have a short video:
    [YOUTUBE]G4aCaU6OnYM[/YOUTUBE]
      Installation in Mk6 Golf (via cabin) - courtesy jamesatfish
      Originally posted by jamesatfish
      Okay - so the good news is you can install the unit in a Golf R from within the cabin, without needing to pull off the wipers etc from the engine bay. I didn't take photos along the way but will have to dig in there again later (see the bad news) so will update the post with pics then.
      1. Pull off the fuse panel cover (driver's side).
      2. Pull out the cubby box to the right of the driver's knee (under the headlight switch). To do this, open it fully, squeeze the sides at the top and the top of the box will open even further. From there simply pull out from the bottom and it will slide off the hinges.
      3. Move the large relay panel out of the way. Undo the clip to the left and the panel will swing towards you. Use 2 long cable ties to hook around the relay panel and pull it up out of the way so it sits above the gap opened up by the cubby box. You can hook the cable ties through the top frame of the fuse panel.
      4. You will see a small plastic box with a single hex screw on the right and a browny/yellow connector on the top. Undo the screw and pull that plastic box out towards you. There is plenty of length on the cable for you to pull the box out without undoing the connector on the top. You will need to jiggle the box to squeeze it through the space to the left of the screw but it will come out.
      5. The magic red plug gateway box is now visible. From here you can either try to unplug the connector with the box where it is, or if you jiggle the box itself you will find that it comes away from the two plastic clips that hold it in place. Once loose you can pull it out of the same space to the left of that screw you undid in step 4. Again there is enough cable to pull the box out to where the cubby box lives.
      6. Connect the FIS+ unit, test and confirm everything is OK.
      7. From here you have 2 choices - put everything back as it came out, or put the browny/yellow top box back in first so the gateway box remains more accessible. I chose to do this, which means that the two boxes I pulled out of that space aren't clicked into the original mounting spots. They are however jammed in pretty tight in there so I can't see that being an issue as they're certainly not going to move around.
      8. If you want to keep the FIS+ unit accessible, run the cord over the top of the relay box when you put it back in place. The relay box is shaped like an L so there's room on the top for the FIS+ cable to run past.
      9. Put everything back together in the reverse order from above.
      I've put together a very quick install video for the Golf R - it claims to be '30 seconds' but ended up taking almost 2 minutes.
      Note that the step you don't see on the video was that the first time the relay box is moved there is another unrelated controller between relay box and the gateway with the red plug. I had already moved that out of the way on my first install attempt - it is just tucked in behind the gateway box to make the swap-over easier.
      Although the FIS+ box is just left tucked in behind the cubby hole I haven't noticed any rattles as yet, though I do plan to put some velcro on the back of it to secure it a bit more.
      And a useful tip from Ryan_R:
      Originally posted by Ryan_R
      I'd like to add the suggestion for the cabin install, if you're struggling to lift up the gateway module, you can get a long flat head screwdriver and leverage it under the small notch near the bottom of unit as shown towards the right of this photo:
        Tiguan
        Installation of FIS+ in Tiguan
        OK after much searching I've finally located the CANBUS gateway in my Tiguan. It's in behind the glove box - requires removal of the glovebox and it is very simple install once this is removed.
        Glovebox removal instructions (thanks to bambazonke):
        1. Remove 5 torx screws (3 at top and 2 at the bottom)
        2. Unclip side panel by wedging upwards and then pulling out from rubber door seal
        3. Wedge carefully out cubby hole light and unplug
        4. Slide glove box out and then unclip rubber tube from air con to cool glove box
        5. Unclip glove box light switch from the back of the glove box near the air con tube as discussed in step 4
        6. Unclip open/close contact switch from centre back of glove box housing
        Then you'll see that gateway connector right in front of you:
        7. Assembly is in reverse order.
        I've stashed the Autopolar FIS+ box just under the removable trim in the footwell so there's only a wing nut to undo and easy access to the unit for future firmware upgrades.
          Jetta
          FIS+ Installation for Mk5 Jetta - courtesy of gigitt
          Originally posted by gigitt
          I tried going through to the CANBUS controller from the inside but I had another controller in front of it and I could not push it out of the way to get to the CANBUS connector... so I went in from the rain tray (refer instructions for Golf Mk6 here)
          IMO going from the top through the rain tray was much much easier. There are only 2 stumbling blocks...
          1) getting the wiper arms off the spindle after you undo the nut - trick is to grab the wiper blade with right hand and hold it just off the glass then with the left hand grab the spring loaded hinge and gently push down then pull up again and again and it will walk off the spindle.
          2) Getting the wiper mechanism out - trick is to take out the torx bolts. move the wiper mechanism towards the center of car till you can drop the side part down under the mounting location, then shift it back up under the windscreen towards the side of the car. Now rotate the front of the mechanism up and the center part will now slide up and out then just gently wiggle the wiper mechanism up and out towards the center of the car.
          What I also did was put some split loom tube over the FIS+ connection cables so it does not rub and wear against anything under the dash.
          Some additional tips,
          • Remove coin tray under headlight switch - there is no need to touch relay panel.
          • Take out windscreen wiper motors and use the Trap door under the windscreen to connect you harness to the CANBUS module.
          • Connect the FIS harness and poke the cabling down the LHS (side where the steering column is) of the Plastic compartment where the Modules are. There is a gap and the new style of Harness will reach all the way down to under your steering wheel.
            Go inside your car raise and pull out steering wheel to MAX. Stick you hand inside cubby hole and in gap under steering wheel and connect the FIS box.
          • Put FIS box under the steering wheel, rest it on top of the lower kick panel where the gap is. use double side tape if you want.
          • Put every back you took off the car.
            Passat
            Install guide for Passat..... coming soon
              Scirocco
              Install guide for Scirocco..... coming soon
                EOS
                Install guide for EOS.... coming soon
                  Skoda Octavia Installation
                  OK so now there 's no excuses of you have an Octavia
                  Originally posted by zei20t
                  Here is a simple guide for installation into a RHD Skoda Octavia 1Z Face Lift model.
                  The pictures are from my 2011 Octavia RS Australian delivered model, however its possible all RHD models will be similar.
                  Make sure your Polar FIS+ has the latest version of firmware. For all Australian delivered models, you need the WHITE version.
                  I don't have pictures for all steps, only the critical ones.
                  1. Remove battery. This step is ESSENTIAL.
                  2. Remove the headlight switch. Turn to OFF, push the knob in and turn clockwise until it clicks. Then pull the whole unit towards you. Unplug from loom.
                  3. Remove the silver (black) headlight switch surround. It just unclips.
                  4. Remove the silver (black) trim on the other side of the steering wheel. It also unclips, but you may need to lever it GENTLY from the bottom.
                  5. Remove the fuse box cover from the right-hand end of the dashboard, where the door trim meets the dash. Use a screwdriver, or your car key.
                  5. Remove the screws to the panel below the steering wheel. With steps 3-5, you uncovered 3 of them. They are located, to the left and right of the steering wheel, behind the fuse cover panel, and two at the bottom of the panel. You'll need a torch to see them. They are torx screws, cant remember the size.
                  6. Remove the whole panel by pulling it gently towards the seat, be careful of the consult port.
                  8. The area behind where the 'pocket' was has a few relays. You need to remove the top-front section. The picture shows the clip:
                  9. Now you should see a glimpse of the gateway, its the blue plug at the back of this photo:
                  10. The blue plug is a little difficult to remove at first. The clip is on the back (faces the front of the car) so you'll need to bend your hand into a position that normal humans cant. For some reason, I had no problems.
                  11. You'll be left with this plug. Join it up with the Polar FIS loom. Plug the other end into the gateway, and finally the 3rd plug goes into the Polar FIS.
                  12. Mount the Polar FIS box somewhere you can access it easily for upgrades, or leave the USB cable plugged in and leave the cable in the 'pocket' or behind the fuse box cover.
                  13. Do steps 1-8 in reverse to re-assemble.
                  14. Enjoy.
                    Golf Mk V Installation
                    Location of CANBUS gateway in MY 07 MK5 Golf 2.0L TDI (courtesy of Transporter)
                    Originally posted by Transporter
                    The CANBUS gateway is located above the accelerator pedal and can be accessed after removing small compartment on right hand side of the dashboard, just swivel it down then squeeze the sides of it and push further down to pull it out.
                    Pinch the tab - pos. 1 in the picture then gently pull towards you and carefully move it to the left, so you can put your hand inside to reach the canbus connector.
                    You can then disconnect the battery, remove the red canbus connector and plug in the cable that comes with the FIS+ unit. Finally install the FIS+ unit and find a suitable place to secure it, reconnect the battery and replace the items you have moved in reverse steps.
                      Parameter List
                      Complete list of all parameters available
                      Name
                      Description
                      1 VELOCIDAD Real Speed extracted from ECU motor
                      2 TEMP_EXT External Temperature
                      3 RPM RPM Engine
                      4 V_BAT Battery Voltage
                      5 FUEL_LIT Petrol Tank Litres
                      6 TEMP_OIL_CAL Calculated Oil Temperature
                      7 TEMP_OIL_ACT Measured Oil Temperature
                      8 TEMP_AMB Engine Ambient Temperature
                      9 TEMP_INTAKE Intake Air Temperature
                      10 TEMP_COOL Cooler Temperature
                      11 TEMP_ENG_OUT Engine Coolant Output Temperature
                      12 TEMP_RAD_OUT Radiator Coolant Output Temperature
                      13 TEMP_FUEL Fuel Temperature
                      14 PRES_BOOST_SPE Request Boost Presure
                      15 PRES_BOOST_ACT Measured Boost Pressure
                      16 PRES_ATMOS Atmospheric Pressure
                      17 IMAP Intake Manifold Absolute Pressure
                      18 PRES_FUEL_SPE Required Fuel Pump Pressure
                      19 PRES_FUEL_ACT Measured Fuel Pump Pressure
                      20 PRES_FUEL_RAIL Fuel Rail Pressure
                      21 PRES_BRAKE Brake Pedal Pressure
                      22 PRES_BRAKE_BOOST Brake Pump Pressure
                      23 LOAD_CAL Calculated Engine Load
                      24 LOAD_ACT Measured Engine Load
                      25 MAF1 Mass Air Flow
                      26 MAF2 Mass Air Flow
                      27 ACC_PEDAL_1 Acelerator Pedal Position
                      28 ACC_PEDAL_2 Acelerator Pedal Position
                      29 ACC_VALVE_1 Acelerator Valve Position
                      30 ACC_VALVE_2 Acelerator Valve Position
                      31 TORQUE Engine Torque
                      32 POTENCIA Engine Power (HP)
                      33 OIL_LEVEL Oil Level
                      34 OIL_MIN_LEVEL Oil Minimun Level
                      35 INJ_TIMING Injection Timing
                      36 IGN_ANGLE Ignition Angle
                      37 MIS_SUM Misfire Sum
                      38 MIS_1 Misfire Cylinder 1
                      39 MIS_2 Misfire Cylinder 2
                      40 MIS_3 Misfire Cylinder 3
                      41 MIS_4 Misfire Cylinder 4
                      42 MIS_5 Misfire Cylinder 5
                      43 MIS_6 Misfire Cylinder 6
                      44 MIS_7 Misfire Cylinder 7
                      45 MIS_8 Misfire Cylinder 8
                      46 MIS_9 Misfire Cylinder 9
                      47 MIS_10 Misfire Cylinder 10
                      48 MIS_11 Misfire Cylinder 11
                      49 MIS_12 Misfire Cylinder 12
                      50 MIS_X1000_1 Misfire Cylinder 1
                      51 MIS_X1000_2 Misfire Cylinder 2
                      52 MIS_X1000_3 Misfire Cylinder 3
                      53 MIS_X1000_4 Misfire Cylinder 4
                      54 MIS_X1000_5 Misfire Cylinder 5
                      55 MIS_X1000_6 Misfire Cylinder 6
                      56 MIS_X1000_7 Misfire Cylinder 7
                      57 MIS_X1000_8 Misfire Cylinder 8
                      58 MIS_X1000_9 Misfire Cylinder 9
                      59 MIS_X1000_10 Misfire Cylinder 10
                      60 MIS_X1000_11 Misfire Cylinder 11
                      61 MIS_X1000_12 Misfire Cylinder 12
                      62 AD_1 Angle Delay Cylinder 1
                      63 AD_2 Angle Delay Cylinder 2
                      64 AD_3 Angle Delay Cylinder 3
                      65 AD_4 Angle Delay Cylinder 4
                      66 AD_5 Angle Delay Cylinder 5
                      67 AD_6 Angle Delay Cylinder 6
                      68 AD_7 Angle Delay Cylinder 7
                      69 AD_8 Angle Delay Cylinder 8
                      70 AD_9 Angle Delay Cylinder 9
                      71 AD_10 Angle Delay Cylinder 10
                      72 AD_11 Angle Delay Cylinder 11
                      73 AD_12 Angle Delay Cylinder 12
                      74 TEMP_EXHA_1 Exhaust Temperature
                      75 TEMP_EXHA_2 Exhaust Temperature
                      76 TEMP_E_CAT Catalyzer Input Temperature
                      77 AFR_LAMBDA_1 AIR/FUEL Ratio (LAMBDA 1)
                      78 AFR_LAMBDA_2 AIR/FUEL Ratio (LAMBDA 2)
                      79 FUEL_TRIM_1_3 Fuel Trim Bank 1/3
                      80 FUEL_TRIM_2_4 Fuel Trim Bank 2/4
                      81 N75_SPE N75 Duty Cycle Specified
                      82 N75_ACT N75 Duty Cycle Actual
                      83 INJ_QTY Injection Quantity
                      84 INJ_START Injection Start
                      85 INJ_DUR Injection Duration
                      86 INJ_START_QTY Injection Start Quantity
                      87 INJ_QTY_1 (D.1 m/str) Injection Quantity 1
                      88 INJ_QTY_2 (D.2 m/str) Injection Quantity 2
                      89 INJ_QTY_3 (D.3 m/str) Injection Quantity 3
                      90 INJ_QTY_4 (D.4 m/str) Injection Quantity 4
                      91 INJ_QTY_5 (D.5 m/str) Injection Quantity 5
                      92 INJ_QTY_6 (D.6 m/str) Injection Quantity 6
                      93 INJ_QTY_7 (D.7 m/str) Injection Quantity 7
                      94 INJ_QTY_8 (D.8 m/str) Injection Quantity 8
                      95 INJ_QTY_9 (D.9 m/str) Injection Quantity 9
                      96 INJ_QTY_10 (D.10 m/str) Injection Quantity 10
                      97 INJ_QTY_11 (D.11 m/str) Injection Quantity 11
                      98 INJ_QTY_12 (D.12 m/str) Injection Quantity 12
                      99 EGR_1 EGR Duty Cycle, EGR 1
                      100 EGR_2 EGR Duty Cycle, EGR 2
                      101 CHAR_PRES_CTR_SPE Charge Pressure Control Specified
                      102 CHAR_PRES_CTR_ACT Charge Pressure Control Actual
                      103 TEMP_PRE_TURBO Temperature Prior Boost
                      104 DPF_TEMP_1 DPF Temperature, DPF 1
                      105 DPF_TEMP_2 DPF Temperature, DPF 2
                      106 DPF_VOL_1 DPF Oil Ash Volume, DPF 1
                      107 DPF_VOL_2 DPF Oil Ash Volume, DPF 2
                      108 DPF_LLENADO DPF Filling
                      109 DPF_CONT_REG DPF Regeneration Counter
                      110 TEMP_E_DPF DPF Input Temperature
                      111 TEMP_S_DPF DPF Output Temperature
                      112 LATERAL_G G Lateral Force
                        Mirror Dipping Feature - Setup
                        OK here's a short video off my phone showing set-up of mirror dipping feature on AutoPolar FIS+ Advanced.
                        The key thing that I think a lot of people get wrong is selecting the mirror positions before selecting either manual or auto. If the mirror dipping is set "OFF" then selecting the positions has no effect. First select "manual" or "auto" and second step is to set the "normal/driving" and "parking/reversing" positions.
                        "Manual" mode setting requires the mirror selector switch to be set to "R" and reverse gear to be selected for the passenger mirror to dip to the selected position.
                        "Auto" mode will dip the mirror irrespective of the mirror selector switch, however the car must be in reverse with indicator lights on.
                        If you don't have mirror dipping as a standard feature you may find that the mirror does not return to exactly the correct position. If this is the case you can use the adjustment menu and select + or - amount as an offset the the return position.
                        I got this working for the passenger side mirror, but found I had to swap to select drivers mirror on the selector knob to get dipping on the left mirror after restarting the car. I think this is a special RHD "feature" that may get fixed in a future firmware release.
                        There's also a function to get both mirrors working at the same time - if you select right both will move, but if you select left then only left moves. That's one of the other options in the mirror menu (Alt. mode).
                        Mirror dipping is not supported on both mirrors at the same time as the drivers mirror is not connected to the ECU - only passenger mirror. Hence only passenger mirror can be controlled via command to the ECU.
                          List of Additional Functions
                          Complete list of all functions available
                          Name
                          Description
                          1 TVFree_function TV-Free function to see video in motion
                          2 Battery_drain Battery drain fix for vehicles equipped with RNS-510 and old gateways before index "K"
                          3 Parktronic emulation Parktronic OPS emulation function (see Parktronic screen in RNS510 with Parktronic PDC ecu) (only available with Skoda vehicles)
                          4 Blink function Comfort blinkers configurable from 3 to 10 blinks
                          5 Mirror function Mirror lowering function (passenger mirror goes down to a configured position when engage reverse gear)
                          6 BT_compatibility (White_DOT) Add BT Hands free compatibility with White dot Hands free units (Can works with all models of BT for white dot cars up to this date)
                          7 RNS-510_hidden_menu Activation / deactivation of RNS-510 hidden menu
                          8 Diag 1 DIAG : 1 - Adjust sensibility percentage automatic wiper
                          9 Diag 2 DIAG : 2 - Adjust sensibility percentage automatic lights
                          10 Diag 3 DIAG : 3 - Activation/Deact. Daytime running lights
                          11 Diag 4 DIAG : 4 - Activation/Deact. cornering lights
                          12 Diag 5 DIAG : 5 - Activation/Deact. american lights
                          13 Diag 6 DIAG : 6 - Activation/Deact. cornering lights
                          14 Diag 7 DIAG : 7 - Activation/Deact. warning lights (blinkers)
                          15 Diag 8 DIAG : 8 - Activation/Deact. of second rear fog light
                          16 Diag 9 DIAG : 9 - Activation/Deact. windows automatic rain closing
                          17 Diag 10 DIAG : 10 - Activation/Deact. automatic closing at 20 Kmh
                          18 Diag 11 DIAG : 11 - Activation/Deact. one touch closing
                            Polar FIS+ Advanced, What is it ?
                            Advanced Polar FIS is the evolution of FIS + unit. It adds new parameters in addition to new features.
                            Polar FIS + enabled viewing vehicle parameters in the FIS screen, but Polar FIS Advanced, as well as incorporating more parameters, includes new features like the ability to modify the number of flashes of intermittent comfort indicators, function automatic lowering of the mirror on the passenger side when engaging reverse and some functions which are can only be activated with Diagnostic cable such as VCDS.
                            Which vehicles are compatible with Polar FIS+ Advanced
                            Same as Polar FIS +, are listed below:
                            - Volkswagen Golf V (1K)
                            - Volkswagen Jetta (1K)
                            - Volkswagen Caddy (2K)
                            - Volkswagen Tiguan (5N)
                            - Volkswagen Touran (1T)
                            - Volkswagen EOS (1F)
                            - Volkswagen Passat (3C)
                            - Volkswagen Scirocco (1K)
                            - Skoda Octavia (1Z)
                            - Seat Leon
                            - Seat Altea
                            What parameters can be displayed with Polar FIS+ Advanced ?
                            - Oil temperature (° C / ° F)
                            - Coolant temperature (° C / ° F)
                            - Outdoor temperature (° C / ° F)
                            - Fuel remaining (Litres / Gallons)
                            - Rpm motor
                            - Pressure turbo.
                            - Voltage of the battery.
                            - Atmospheric pressure
                            - Pressure fuel pump
                            - Motor load.
                            - Ambient Temperature (engine ECU)
                            - Coolant temperature engine output.
                            - Coolant temperature leaving the radiator.
                            - Mass air flow.
                            - Sensor 1 throttle pedal.
                            - Sensor 2 throttle pedal.
                            - Sensor 1 throttle valve.
                            - Sensor 2 throttle valve.
                            - Horse Power used cv.
                            - Oil level.
                            - Minimum oil.
                            - Brake master cylinder pressure.
                            - Pressure in the fuel rail.
                            - Torque used NM.
                            NOTE: Not all parameters are supported in all engine ECU, to know that data can be displayed, see the list of supported ECU: http://www.auto-polar.com/downloads/Supported_ECUs.xls
                            What is the role of intermittent comfort ?
                            The role of intermittent comfort, allows you to select the number of intermittent flashes that the comfort indicator makes. Standard, with one touch gives 3 flashes intermittently with Polar FIS Advanced, select up to 10 flashes.
                            You can also cancel additional flashes by pressing the indicator comfort again, for example, if you have set the indicator at 10 flashes on comfort, it will flash with a short press on the control 10 flashes, unless pressed again to cancel.
                            What is the function of mirrors down ?
                            Advanced Polar FIS can be configured to engage on selection of the reverse gear for the passenger mirror to dip down automatically to a preset position. There are 2 modes: Manual and Automatic.
                            In manual the mirror will lower only if the passenger position “L” is selected.
                            In automatic, the mirror will be lowered only when the car is parked with the indicator directed towards the space.
                            NOTE: Due to construction features of vehicles it cannot be guaranteed that mirror position will be "perfect". On models equipped with this function from factory the mirror incorporate a position sensor, which does not happen with those without park assist mirrors, so the mirror will function in the same way, but can not be guaranteed to position "millimeter perfect".
                            What diagnostic functions are available ?
                            - Modification of the sensitivity of the rain sensor.
                            - Modification of the sensitivity of the light sensor.
                            - Enable / Disable American DLR.
                            - Enabling / Disabling daytime running lights.
                            - Enabling / Disabling cornering fog lights.
                            - Enabling / Disabling second rear fog light (where bulb exists).
                            - Enable / disable automatic closing from 15 km / h.
                            - Enable / disable rain closing.
                            - Enabling / Disabling one touch closing windows.
                            - Enable / Disable hazard warning in case of sharp braking.
                            NOTE: These functions, Polar Advanced FIS performs are via coding of the ECU with the requested function, so if this function is not supported by your vehicle ECU, then it cannot be activated.
                            What are the other features of the Polar FIS+ Advanced ?
                            - Built in VIM to enable video on stereo screen while vehicle is in motion.
                            - POLAR Advanced FIS supports OEM bluetooth and Fiscon bluetooth, unlike other products, POLAR Advanced FIS does not use the Bluetooth menu in the FIS, but creates a new menu called Advanced POLAR FIS.
                            - The name of the created menu is customisable, which can substitute the name POLAR Advanced FIS by the text you want (up to 10 characters)
                            - Option to turn off the POLAR Advanced FIS screen off making the unit undetectable when taking the car in for service or repair. Is reactivated by simply pressing the OK button on the steering wheel or windshield wiper lever for 10 seconds.
                            - Automatic temperature units (° C, ° F), Speed (kmh / mph) and Size (Litres / Gallons) selected in the FIS.
                            - Manual selection of the units in which you want to display the parameters relating to pressure. Automatic, mbar, bar, PSI.
                            - Multi-function steering wheel / Wiper stalk control.
                            The keys can be set from within the FIS POLAR Advanced menu do the following.
                            Modify volume.
                            Changing audio track.
                            Change the parameters displayed in the bottom of the screen line POLAR FIS +.
                            You can also configure the keys inside the AUDIO menu do the following.
                            Modify volume.
                            Change audio track (useful for cars in which the multifunction steering wheel is not installed at the factory and these keys do not work).
                            IMPORTANT: FOR CARS THAT ARE NOT EQUIPPED MULTIFUNCTION STEERING WHEEL, THE OPTION OF CHANGING AUDIO TRACK IS NOT AVAILABLE.
                            KEY FEATURES OF THE WHEEL IS NOT AVAILABLE IN ALL THE VEHICLES, since it depends on the vehicle configuration.
                            - Polar Advanced FIS automatically installs itself in the gateway, so you do not need diagnostic software after installation
                            - Updates via the Internet, via our website: Autopolar Official Web site
                            - New aluminum frame.
                              Boost Pressure
                              This is where this whole thing started with me looking to get boost pressure displayed in the MFD.
                              There's a few options with how to display boost pressure - you can select units (mbar, bar, psi) and also where the data is sourced from (auto/infotainment/diagnostic).
                              Here's the full details on boost pressure - original post is here: INFO : Some detailed info about "TURBO PRESSURE" parameter (Read this before ask)
                              TURBO PRESSURE parameter (extended info)
                              How to configure you PolarFIS to correctly read turbo pressure
                              To read turbo pressure, normally it is not necessary to configure anything in your PolarFIS unit.
                              There is a configuration inside the box that automatically selects the best option to read turbo pressure.
                              However, there's a few models which this automatic function doesn't work.
                              This guide will help you to identify if this is your case.
                              These are available options in the turbo pressure menu:
                              - AUTOMATIC : PolarFIS will select the best option for your vehicle automatically. RECOMMENDED !! (by default)
                              - INFORT X1 : Obtain the turbo pressure from the infotainment bus.
                              - INFORT X2 : Obtain the turbo pressure from the infotainment bus. The reading is then multiplied by 2 (only vehicles in which the bus shows half pressure).
                              - DIAGNOSIS : Obtain the turbo pressure from the diagnosis bus, recommended in vehicles that the other options don't work.
                              What values does the PolarFIS show in my screen ?? I not have idea ...
                              The value that PolarFIS displays is the result of subtracting the barometric pressure from the boost pressure read from the bus.
                              This is due to the boost pressure sensor indicating values in absolute pressure (BOOST+BAROMETRIC)
                              But, sometimes i see negative values, why does this happen??
                              Normally with the engine at idle there will be a small vacuum in the intake manifold, so reading will be negative (around -5 to -15 mbar or -0.07 to -0.2 PSI). This is normal.
                              However, in some models there's no negative readings and with engine at idle the reading is 0 mbar or 0 PSI, we can't do anything about that because this reading is done directly from the Diagnostics bus of the engine ecu.
                              However, a small negative reading as indicated is normal, but if you have a reading less than -100 mbar or -1.4 PSI it means that boost is not reading correctly.
                              In this case, you must enter into the Polar FIS configuration menu, and select SCREEN->VISUALIZATION->ADVANCED->BOOST OPTIONS and choose the option INFORT. x2.
                              This is due to pressure read from infotainment bus being divided by 2 in some cars.
                              If the problem persists or you have no reading of boost pressure, enter in the same menu and choose DIAGNOSTICS option.
