Originally posted by aussietig
View Post
Tiguan Canbus Gateway - Location???
I haven't figured out the auto mirror dipping either (actually forgot about it until now). I gave it 3 attempts using my IT/common sense approach with no success, so waiting for proper instructions.
Originally posted by Ryan_R View PostI haven't figured out the auto mirror dipping either (actually forgot about it until now). I gave it 3 attempts using my IT/common sense approach with no success, so waiting for proper instructions.
Gurus @ Rosstech confirmed that dipping mirrors only work on Tigs with folding mirrors or top spec SEL model in the US.MY11 Tiguan 147TSI (SOLD)
Originally posted by aussietig View PostDon't think it's gonna work, as it is hardware problem as oppose to software.
I'm just wondering if there is something that is a giveaway in the scan that can tell you if you have the required hardware/wiring connections or not.
Originally posted by aussietig View PostYes ... folding side mirrors! No need to scan anything.
If it depends on the car hardware then why couldn't you enable these features previously using VCDS?
Originally posted by Ryan_R View PostIf it depends on the car hardware then why couldn't you enable these features previously using VCDS?
1) whether you have the physical connection from ECU to mirrors
2) whether the car has the ability to store/memory for mirror position
If you don't have 1) then it's never going to work.
If you have 1) but not 2) then the FIS+ can act as the mirror position memory unit. This may not be as accurate positioning as the "factory fitted" mirror dipping function, however you will still be able to use this feature.
This is the difference between enabling the function in VCDS and in FIS+. With VCDS you require the memory unit to be present in the car. With FIS+ if you don't have the mirror memory then FIS+ will perform this function.
That's my understanding at the moment. Though I'm still looking to get clarification from AutoPolar.
Ah thanks, makes sense. Strange that some cars would have #1 by itself though while others don't.
Once you get it sorted be sure to ask them to update their advertising to reflect what cars it can be used for, and maybe hide the menu on the Golf, etc.
Just confirmed that mirro dipping actually does work in the Tiguan - got the function working so all the necessary hardware must already be there.
Happy days
Originally posted by Gusu View PostHello. Iam very tempted to order one for myself (Tiguan 2011). Did you by any chance happen to take a picture with the Polar box installed?
Did you disconnect the battery when you switched that red canbus connector?
Though if you are in Sweden the location of CANbus gateway my be different as you have LHD???
Yes recommended to disconnect the battery when connecting/disconnecting the CANbus connector.Last edited by tigger73; 13-03-2013, 12:58 PM.
