I still get a loud oscillation sound and pop when I cold boot the unit with the engine on my H unit, going back to 4020 stops it though.
New firmware for RNS510/Columbus versions 4120 and 5210
Interesting. No idea what it could be. Can you detail all audio accessories you have ie BT unit including model/rev anything aftermarket, MDI etc etc.Originally posted by readerr0r View PostI still get a loud oscillation sound and pop when I cold boot the unit with the engine on my H unit, going back to 4020 stops it though.
Given that the firmware rev affects it should be something you can avoid with a setting somewhere...2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
No probs.Originally posted by l3lazin View Postkamold your a legend mate. I have a C unit which had been upgraded to 90/5/5 from your previous firmware that you did.
All went to plan, no issues at all. I now have Radio text.
Once again, thanks alot for putting your time and effort into creating these firmware builds for us! Also thanks to all the guys above for maning up and having a go before me.
Will look to revising the main firmware guide shortly with this version once I get confirmation of partitioning working properly.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
I've got factory MDI and BT in my Polo and then it's running through to an amp in the boot, I've got the VW Soundsystem option selected so it provides low-level RCA sound to the amp. I'm then using the CD Changer remote line as a remote for the amp.Originally posted by kamold View PostInteresting. No idea what it could be. Can you detail all audio accessories you have ie BT unit including model/rev anything aftermarket, MDI etc etc.
I'm not sure if it's a bug with the Sound System option or if the CD Changer remote line if turning on earlier than usual, but it all goes back to normal with 4020...
At the moment it's a non-issue since going to 4020 keeps the radiotext, I just hope it gets cleared up in newer frimwaresMY16 Octavia RS 162 Race Blue Combi
Re: New firmware for RNS510/Columbus versions 4120 and 5210
Ok so its triggering the amp that's the issue. Possibly they changed the order that modules are started in the rns to boot faster or something...
Sent from my HTC One X using Tapatalk 22011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
remind me again - do i need to reboot after i put the dvd in, or do i simply follow the prompts?
i plan on taking the plunge tonight.
i'm currently on 402x.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Yes, many forget that last bit. That said I once did a firmware installation while driving home from work (had run out of battery after numerous failed attempts)
Does this FW upgrade also include new maps? Can anyone from Brisbane comment on how up to date they are? Also, to save me starting a new thread, I just bought a GTI with RNS510, I thought it had bluetooth as it had a phone button on it but now I'm thinking it doesn't
 Is there a way to retrofit bluetooth?
there are no maps in the firmware update. and if you download the version from this thread, you will lose everything stored on the hard drive - unless you had a kamold custom map installed before - there is (was) a V5 map floating around that is fairly up to date.
Maps are a separate CD - can find them in a stickied thread in this section.
Bluetooth can be retrofitted, many threads about it here. Check carsystems.eu or ebay for purchasing. DIY is fairly easy if you can wire up your home A/V system.
i was under the impression you don't loose anything if you upgrade from 402x, as it already has the 90/5/5 partition?Originally posted by zei20t View Postthere are no maps in the firmware update. and if you download the version from this thread, you will lose everything stored on the hard drive - unless you had a kamold custom map installed before - there is (was) a V5 map floating around that is fairly up to date.
i do have the v5 maps disc, incase i have to reload.
i can always reload my music.
but vcds settings (for bluetooth), rns language, vim etc etc - i don't want that lost.MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Correct: if you already have the 90/5/5 partition scheme you won't lose anything.Originally posted by dArK5HaD0w View Posti was under the impression you don't loose anything if you upgrade from 402x, as it already has the 90/5/5 partition?
If you had previous 2 partition setup from 2760 etc, or standard 3xxx series with 50/25/25 then music and maps would be lost also.
Coding is maintained with this version.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
so 30 mins later, i've now got the new firmware running.
was a smooth install.
didn't loose any settings on the rns510.
i'm yet to check bluetooth & vim.
i've lost the custom boot screen, but that was expected.
will reload this soon.
based on 5 mins of playing around - radio text is a hit or miss, depending on the station.
haven't seen any weather information yet.
thanks kamold for making the iso available. as usual, u made it a simple & painless experience. 1st with the 402x series, and now the 412x series.
i gotta buy u drink or something next time i'm in sydney!!MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
