Rain sensor cactus
  • Rain sensor cactus
    My rain sensor has stopped working. Checked fuse - all good. Shut car down and restarted, same problem. Anything else I can do before heading off to the dealer for a warranty repair?
    Get it to stop raining? I'd appreciate that as I have a heap of work to do outside that's been pushed back for weeks...
      Thank the gods for making it happen while the car is still under warranty!
      Volvo S60 RD T6
        Mmm. Now it's working again this morning. Will it have thrown up and captured a fault code or something so the dealer can log its history? It would come in handy if it fails completely the day after warranty expires.
          What made you say it "stopped working" in the first place?
          If the windscreen is wet when you start the car, then you need to switch it on and off, or toggle sensitivity up and down. Sometimes in light rains it gets itself stuck on too - same thing applies.
          I parked my car undercover at home and work, so never knew that until I'd had the car about 2 months (the starting one, not the other one - my Renault used to do that)
          Al..
          2013 MY13.5 Passat V6 Highline Wagon. Watch this space
          GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
            Easy way to tell if it is indeed working when you suspect it isn't, leave the ignition on with the auto wipers turned to on, get yourself a spray bottle or garden hose and sprinkle the entire windscreen with water. If the wipers do nothing, then it's probably stuffed. I they work, it's fine. All it is is a photosensitive receiver and LED. If the photosensitive receiver gets interrupted, it triggers the wipers.
              Al..
              Yeah all that. I've had the car for nearly three years and am fully aware of all of the intricacies of the rain sensing system. Stopped working means it stopped working.
                Not sure about VW but on my 320d the rain/light sensor is an integral part of the windscreen and is was replaced when my windscreen was cracked so I would make sure you have free windscreen replacement ticked in your car insurance premium to cover any future events
                Mods: VCDS tweaks |
                  Good point.
