Firmware updates for European RNS510 units
  • #31
    Hi,
    yesterday I installed the custom firmware 4020 with the ratio partitions for Europe and it works great
    Thank you guys for the job!
    • #32
      Originally posted by kamold View Post
      Thanks. I presume that is the 402x firmware ISO?
      Any chance you could also upload the 38xx firmware ISO with Euro partition sizes as well?
      Then we can have a complete guide for Europe with pre-made images...
      here is the 3810
      while we start European thread, can i upload Tomtom Speedcam and someone can help add them to the POI?
      and upload and share with the commity? i am sure i am not the only one from Europe here!
      • #33
        i am uploading the 4020 for Unite A/B/C for Europe users
        will share the links soon and please update the first link!
        edite
        please add to the first post this 4020 for Unite A and B and C with European Partition
        • #34
          So this has table swap for early units, has the Dlscript.txt been modified for 70/25/5 partitions?
          • #35
            which dlscript file shows this?
            Let me know where to look, and I'll post up the file contents
            • #36
              Sorry Steve am away this weekend.
              Check the old thread for modifying 267x firmware I think it shows the path.
              Line is multi verify something something.
              • #37
                Found the thread....can't make sense of what to look for inside the file (found the file...but the contents don't seem to provide a clue for the partitioning sizes).
                Will wait until you get back
                • #38
                  i am using it now on B Unite and i copied the EU map which is 4.5GB, all is fine even the POI partition is fine,
                  ---------- Post added at 07:04 PM ---------- Previous post was at 06:57 PM ----------
                  Maybe i can hel you Steve,
                  are you European user?
                  • #39
                    no...sorry. In Australia
                    • #40
                      if you explain the issue i may be able to help,
                      • #41
                        edite
                        I installed this fw on my RNS, previous Version was 2760. The update was successfully finished, but after the reboot the harddisc partition was unchanged, there were still all my MP3s and navigation maps. So I think, there is a little mistake in this firmware.
                        • #42
                          i installed this too, but somehow can't get the POI working, and also the speed limite is not working,
                          so i will go back to Firmware 3810 which worked fine but no POI, still looking for solution will share while i have solution,
                          • #43
                            Do you have after installing of 3810 three partitions in your RNS? Maybe you have only 2 - one for media and the second for maps. That maybe why your POIs doesn't work.
                            I tried your 3810ANORU-M3-EU.iso firmware too, but this image doesn't boot in my RNS. I tried another - standard image of fw 3810 with standard drive partitioning 50/25/25 and after that I apllied 4020 for Unite A and B and C. Now ewerything is working, incl. POI - POI uses the third partition for correct functionality.
                            • #44
                              i applied the same firmware somehow can't get the POI working,
                              are you able to see the speed on the map while driving?
                              what is the extention of your POI?
                              PersonalPOI.db3 or POI.db3?
                              the firmware 3810 has 3 Partition i modife it my self, i am sure is not the Partition but the way how the firmware sees the POI!
                              • #45
                                Try to copy PersonalPOI.db3 file into PersonalPOI folder on your SD card.
                                Then start the import of POIs to your RNS (it must be done manually).
                                You don't have your POIs in menu of yours RNS or zou have them, but they are not visible on your map?
