RNS510 firmware update - only half worked?
  • #16
    This unit is now in my hands. I'll report back whatever I can by the end of the week.
    • #17
      Let me know if you want the diagnostics cable. Just need a bench 12v power supply.
      • #18
        I presume the diagnostics cable different to a VAGCOM cable?
        • #19
          I'd presume they're one and the same
          MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
          2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
          • #20
            It's different, yes. It's what I was talking to you about earlier. & yes to your below comment.
            • #21
              Oh, for RNS510 manager?
              • #22
                No, it's a different cable and the software to VCDS.
                Performance Tunes from $850
                Wrecking RS OCTAVIA 2 Link
                • #23
                  don't mine me......*steps back into the shadows*
                  • #24
                    The cable plugs directly into the rns510 media port. It needs to be on a bench with 12v power.
                    Software is locked to the cable like vcds.
                    • #25
                      Hi Benough,
                      Any luck with your RNS510.
                      As of last night I have the same problem on my wife's Tig. The faulty unit is now also out of the Tig and I am going to try it in my Jetta (wife & I both have dubs with the same RNS-510 setup).
                      Pretry sure I am waisting my time.
                      • #26
                        Nah dude, it's dead.
                        I can get a new motherboard for it, shipped for $200 AUD.
                        Will post up when I get it, unless you want to purchase one yourself, I can give you the contact.
                        • #27
                          Oh Bugger! I was hoping there was a happy ending.
                          Based on your reply I will be returning mine to Harding Performance to see what they can do. It has been less than a year since they installed it in the Tig so hopfully they will cover it under some sort of warrantee.
                          If they find a solution that does not involve a new mobo, I will let you know.
