RNS510 Australia V4 maps out ?
  • #46
    Originally posted by dArK5HaD0w View Post
    how can there be an update when wheris/sensis themselves have said for a while now that there is no update (v17) for vw/audi?!?!?
    the next one, v18 (or 'v4' in vag speak), is not due out till q4 2011, or q1 2012!!
    this "v4" is most likely someone who has probably made some additional custom POIs and categories, re-created the DVD, and given it a new version.
    As per my last few posts...
    Originally posted by Corey_R View Post
    Yeah, so that confirms my thoughts. Their versions are only for the pre-RNS510 sat nav systems.
    • #47
      Jeez ... you're even more sceptical than me!
      But I think what Corey_R is saying is right!
      Maps direct from Sensis are for the MFD2 units.
      The fact that they mentioned CD in their response is a dead giveaway!
      MY11 Tiguan 147TSI (SOLD)
      • #48
        hi all , myself and my brother when half each ($50) in purchasing this v4 off the mentioned ebay seller , did EFT and he posted no worries , i now have it installed in my RNS510 vD , now before i installed i went into the setup secret menu and looked under nav and it stated that v3 is 7004 (something like that cant remember) now the ebay v4 in the setup secret menu under nav shows as 7603 don't hold me to that number as doing off my head ! now i have a my10 MK6 118tis with the MFD2 and my bros got a RNS 510 vD in a my05 MK5 tdi with the MFD1 so i will get together with him this weekend and compare the two and see if i can get POI's woking ! so ill report back and let you know what i find , also as im still new to this if any one has anything they would like me to try within reason to this v4 disc just let me know and ill do my best cheers
        MY10 Black 118TSI Golf , 6sp Man , RNS510 LED , Superchips Stage 1 , 9W7 BT , MDI , RVC , R32 18" Rims , R32 brakes front & rear , Full leather interior , GTI Steering Wheel , GTI pedals, GTI shifter with sigma 6 , THS engine mounts , Eibach 30mm lower springs , APR Carbon induction , Miltek turbo back 2.5 SS + loads more !! its now a 155TSI ish !!
        • #49
          Thank you! Yep, this is the unit which came before the RNS510. I couldn't remember the name of it.
          • #50
            Thanks for the offer!
            All I want for Xmas is confirmation that this v4 disk has working POIs when running firmware (FW) version 3810 or higher on a RNS510 (a.k.a. MFD3) unit.
            You will find what FW version both your RNS510 are on via the secret menu.
            Hopefully all above FW version 2760 (being D units) and with working POIs.
            Thanks!
            • #51
              Another added feature of the higher FW versions currently redundant due to the V3 map is the ability to upload your own personal POIs (created using POInspect0r) via SD Card onto the RNS510.
              So please PM me (any V4 map owners) if you're up for this little test and I'll send you a sample file with 2 speed camera POIs to see whether it works.
              • #52
                How do you get to the secret menu ? I installed last night all OK and certainly the maps have changed (I know one for example right near my place that was blocked off about 2-3 years ago that was not blocked on the old map, but is blocked on the new one). I'm in the Eastern Suburbs in sydney if you want to give it a go yourself. PM Me.
                • #53
                  Answer is in this thread: http://www.vwwatercooled.org.au/f78/...enu-59346.html
                  • #54
                    Also, if someone with the V4 maps can confirm if the unit now shows current speed limit, that would be great.
                    The RNS510 units with the latest Euro maps apparently show the current speed limit of the road you are on, whereby the Aus V3 maps don't.
                    Could be handy....
                    MY11.5 Golf R - Candy White 5 door - still giggling like a child when I drive it!
                    • #55
                      Just PM'd you a thought big W.
                      MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
                      • #56
                        Strange that VW Australia uses Sensis / Whereis maps for the RNS510, but VW everywhere else uses Navteq maps, which are generally updated more frequently. Doesen't guarantee that compilation to suit RNS510 would happen any more frequently, however... My RNS510 is stuck in 2008/9 as well! I live in an area with many new roads, and the system wants me to "make a U-turn if possible" many times...
                        2009MY Jetta 2.0 TFSI 147kW + Leather + RNS510 SatNav + iPod interface + Michelin Pilot Sport 3 Tyres
                        • #57
                          Navteq maps in Australia are terrible compared to Sensis - VW have definitely made the right choice there ....
                          No speed limit is shown using the new maps, unfortunately. Something I was looking for as well.
                          • #58
                            hi all for those following this thread i can confirm that POI's are not available in the menu for the this version of the map (v4) so i conclude that it also wont recognise uploaded POI's ! bummer will have to wait till the end of the year and hope sensis get up to date with ever one else and give us POI's and road speed limits !
                            • #59
                              Yes ... what a disappointment!
                              Met up with wandersen and could see that he had POIs on his (C unit, FW 2720).
                              But none on mine (also C unit but FW 3930) running the same V4 map.
                              So it's literally just a map upgrade, with no file structure change required by FW 3810 or higher, to support things like basic POIs.
                              Let alone, my pipe dream of SD Card upload of personal POIs.
                              Anyhow my advice is to rollback to FW 2760 or lower, if you really want the basic POIs back.
                              Cause they're definitely there on the V4 map!
                              Alternatively, if you don't want to downgrade FW on your D unit, load your favourite destinations via SD Card this way: http://www.vwwatercooled.org.au/f78/...tml#post670541
                              wandersen
                              I will also try and create a modified V4 map (the old school way) with my speed cameras POIs for you to test.
                              Thanks again
                              • #60
                                wandersen
                                Thanks again
                                So when you upgraded to 3810, did you do any intermediate upgrades to ensure you received the new Partitioning that is required by the new maps?
                                I'm still running 2720 on my C (star) unit, and apparently 4000 should be out soon so might look at updating to 4000 and the v4 maps
                                2011 Tiguan | 147TSI | Deep Pearl Black | Corn Silk Leather | Panoramic Sunroof | DSG (7-speed) | 4Motion | Bluetooth | MDI | Reverse Camera | RNS510 | 18" New York wheels | Premium Floor & Boot Mats | VCDS Micro CAN
