VW MY11 Bluetooth - VW 9ZB
  • #76
    Does anyone know if the 9ZB/9W7 part can be integrated with an RCD310 as found in the new Polo's?
    • #77
      Just FYI I have had the new Kit installed in a 2007 Passat. It integrates perfectly with the RNS 510. Phonebook downloaded properly from iPhone 4 and voice dialing works with no issues. This does not work with the red MFD on the Passat, but I chose the kit due to it having no problems with iPhones (as opposed to the Skoda kit). Bluetooth audio also works perfectly and is as clear as using the MDI.
      • #78
        have a rcd 510 fitted in my golf r .
        Wanting the 9zb/9w7 bluetooth unit .
        1 will I miss any features when hooked to rcd vs rns ie voice dialling
        2 if i have an iphone with tom tom loaded can i stream the audio via this unit.?so at least i have a audio gps if not a 6.5 in visual one?
        3 is installation under seat or in dash ?
        4 most sites say it is a plug and play, is it an easy install or specialist only/estimated fit time?
        5 supplementary question can rvc be fitted with and rcd or only in rns
        United Grey Golf r 5 door dsg leather sunroof 19 in wheels mdi
        • #79
          I recently fitted a 9W3 and RNS 510 in my car. If i can do, I'm sure you can. I mounted the unit in the dash under the radio (just behind the A/C controls.
          There are instructions here on the installation. http://www.carsystems.pl/media/instr...oth%20v1.4.pdf
          The trickiest bit is getting the microphone cable through the roof to where the overhead lights are.
          I'll let someone else answer the RCD v RNS questions
          Audi A3
          • #80
            I fitted the 9W7/9ZB to my passat wagon on the weekend, I wrote up some info here
            My RNS510 already had voice activation setup, so I didn't have to do any coding for that, All I had to do was turn on the Telephone module in the can controller (19) in vagcom.
            • #81
              Does anyone know if we order the 9W7/9ZB from eBay if we can then have our dealers install it?
              I am personally not keen on ripping up my dash and headliner and re-programming my car for the bluetooth with abolsutly no experience on the matter.
              But I also dont want to get told from my dealer that they cant order it for me and be asked to pay rip off prices for that $2500 'premium kit'.
              What are people thoughts?
              MK6 GTI 3 Door - Candy White - DSG - Sunroof - 18" Detroit - ACC - PA - RC - MDI - BT - RNS510.
              • #82
                Does it matter what I or someone else things your dealer might do? The only people can answer what your dealer will do, is your dealer.
                • #83
                  That's fine. However the reason I have asked this is to see if anyone has heard or had experience with dealers installing things, as long as you get the genuine part for them.
                  • #84
                    Bluetooth & other options
                    For all you guys who like options: KUFATEC GmbH
                    They do supply to Australia. Contact me if you need an installer in Perth
                    Christian Sieg
                    • #85
                      i have ordered the kit 7P6 035 730B.It is a unit only with no wiring looms/microphone .Is this the right kit?.
                      I have golf r with rcd 510
                      • #86
                        Nope. You need the wiring looms and microphone unless you already have factory bluetooth installed already.
                        2008 Mk5 Golf .:R32/ BMP/ RCD-510/ More to come
                        • #87
                          Can the wiring loom and microphone be ordered separately ?
                          Or is there a separate order code which gets unit and wires+mic.
                          • #88
                            can the wiring loom and microphone be ordered separately ?
                            e...b...a...y
                            • #89
                              Originally posted by Peteaussi View Post
                              e...b...a...y
                              LOL funny, but true... you're better off ordering it with the loom. I looked at the loom before I put it in and I actually couldn't identify a VW part number on it either.
                              • #90
                                Good news maybe bad news.
                                I can get the loom and mic from E B A Y for $130 delivered however i note now that my box is 730 b not 730 c .Does anyone know the difference ?and will it work in my golf r and with the mic/loom for the 730 c?
                                Also any comments on anyone who has installed the unit on the complexity of the install .
                                If the return of my part was easy I would take this option and order complete kit from ebay but not sure if i will be able to do this.
