VW Golf Headunit High Range Signal
  • VW Golf Headunit High Range Signal
    Hi guys, I've got a golf mk7 tsi with a mib2 retrofitted, I'm feeding it into high level into a DSP/AMP, I was reading some places that you can send a full range signal instead of the factory one with eq/filters to protect the default speakers. I'm wanting to send a full range signal.
    There's this setting I've found online under OBDeleven under Multimedia
    Sound_System_external_BOOSTER
    Seeing a bit of info that this sends a full range signal from the headunit but just wanted to confirm before I try it.
    Thanks
    Thanks​
    Registering interest as I wasn't aware of this. I'm also running a MIB2 with a DSP/AMP.
    Golf Wagon MK7 (90 92TSI) - Mods: DQ250 swap (Stage 2), 110TSI turbo upgrade (Stage 2), Bilstein B12, 19" Pretoria, GTI PP sway bar upgrades (front/rear), full GTI tartan interior, GTI colour cluster, R Bi-Xenon headlights with AFS retrofit, GTI brake upgrade.
    More to come...
      There is coding for amplifier/speaker config. It's in bytes 4-7 and byte 11 of long coding.
      But there are also parameters which set the DSP settings. You can read more about them here:
      MIB2 sound settings and datasets are a highly speculated topic: the web is full of comrades who flash “magic” files for money to turn an ukulele into a rock band. Now is a time to shed some light on this. My personal interest was to bring back the separate subwoofer control that existed for the Audi ...
