VW Golf Headunit High Range Signal
  • VW Golf Headunit High Range Signal
    Hi guys, I've got a golf mk7 tsi with a mib2 retrofitted, I'm feeding it into high level into a DSP/AMP, I was reading some places that you can send a full range signal instead of the factory one with eq/filters to protect the default speakers. I'm wanting to send a full range signal.
    There's this setting I've found online under OBDeleven under Multimedia
    Sound_System_external_BOOSTER
    Seeing a bit of info that this sends a full range signal from the headunit but just wanted to confirm before I try it.
    Thanks
    Thanks​
    Registering interest as I wasn't aware of this. I'm also running a MIB2 with a DSP/AMP.
    Golf Wagon MK7 (90 92TSI) - Mods: DQ250 swap (Stage 2), 110TSI turbo upgrade (Stage 2), Bilstein B12, 19" Pretoria, GTI PP sway bar upgrades (front/rear), full GTI tartan interior, GTI colour cluster, R Bi-Xenon headlights with AFS retrofit, GTI brake upgrade.
    More to come...
