My son just upgraded the radio in his mark 6 gti to a RCD330 plus can this model be installed in my 2009 r32 if so is there someone in inner west Sydney that can do this, I would appreciate your feedback on this thankyou
2009 r32 radio upgrade
Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
The RCD330 is a great upgrade for the Mk5 and Mk6 Golf. As for someone who can install it, get in touch with VCDS SYDNEY - Home
First things first you want to check on the CANBUS module and if it will have battery drain issues.
Here is once place to start: Battery drainage issue
As for install, I believe the RCD330 is plug and play, pop the trim, four screws and away you go without needing anything coded otherwise... if you wanted to give it a bash yourself.
RCD 330+ UNBOXING AND INSTALLATION IN VW GOLF MK5 | Android Auto| Apple CarPlay |Team Legal Fit - YouTube
easy way to confirm CANBUS version is - does the R32 have a full height MFD display, or is it a half height version.
Full height is CANBUS V2 - no battery drain issues.
Half Height MFD will be CANBUS V1.6 (?) which is known for not shutting the RCD down completely when the car is switched off (even locked). Update is fairly straight fwd...just need to find the CANBUS module (look up from the drivers footwell) - OR - it may behind the panel in the engine bay (just near the wiper drive shaft - drivers side).
*Fingers crossed you have V2. Being a 2009 model....almost guaranteed
						MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
