Hi All,
Have just swapped my RNS510 for a RCD 330 (Noname 187B) with Car Play and Android Auto. My car is a 2013 Passat Alltrack . It came with Reverse Camera with bendy lines, 97w bluetooth and aux midi input as standard with the RNS 510. Also has park Pilot. I went with a RCD 330 with a rear usb cable and replaced the aux socket in the centre console bin with the usb socket to connect my phone for Android Auto.
I knew the original camera would not work with the new head unit so I ordered a camera kit from the same seller I got the head unit from. This kit requires a new cable to be run up to the head unit. (VW Passat Jetta2012 Tiguan dynamic track parking line handle rear view camera for RCD330G Plus | RCD330 Plus | RCD330G Plus)
I've had a couple of trips away and having Android Auto is a relevation compared to how clunky the old RNS 510 was. Being able to ask for directions is very popular with my better half who ususually had to do battle with the RNS 510 multiple screens to just get down the street ( thats as long as there hadn't been any street changes in the last 7 years.)
Yesterday it was time to install the camera. Ok no problems getting the tailgate trims off and the old camera disconnected. The new one fit exactly as it should and then I turned my attention to the cabling. The new camera has a thin coax cable with a plug that seems to carry all the wires I need. I thought it would be easy but the two cable boots on either side of the tailgate are choc full of wires and its not clear how to get the boot out of the car body. Ive pulled them both out of the tailgate and put a rod down them but I cant seem to get past the car end of the boot and into the headlining. I can feel where the cables come out but I cant get the rod past the opening so at the momemt Im stuck.
@ak7723 mentioned in another thread that he had manaaged it so I suppose I am looking for tips, hints ar anything that might assist. If that isnt possible can anyone recommend a converter that will get any sort of reverse picture on the headunit If I put my original camera back in and use the factory wiring. it wouldnt matter at all about the bendy lines>
Any help from anyone would be greatly apprecaited.
David
David
