RCD510 Reverse camera adaptor
  • RCD510 Reverse camera adaptor
    Hi All,
    A previous owner of my 2012 Scirocco R (pre face lift) has installed an aftermarket reverse camera on the car (the type that replaces the number plate light). All the cabling is there so I'm assuming he had it connected to a different head unit which he must have changed back to the RCD510 before selling it.
    There is a yellow video cable running from the camera all the way to the front.
    The RCD510 has the mustard yellow 26 pin connector
    I've had the rear view camera function enabled in VCDS.
    Where can I buy an adaptor to connect the yellow video cable to the 26 pin mustard yellow connector?
    2012 Scirocco R manual, RD Technik stage 2 tune with Forge twintercooler. Rising blue - currently riding on white work emotion T7R 18x8.5
    Dont think you can as they use different protocols to talk to each other. Has been lots of threads about this without success
      You can use a CVBS to RGBS adapter. Get them from Ali or Ebay.
      Quality isnt the greatest but better than nothing.
        Thanks mate! Looks like they're roughly $130. Any idea what head units I'd be able to plug the RGB yellow cable into directly if I were to go down that path? Aftermarket head unit or a different VW headunit
          Anything aftermarket will use cvbs.
          VW current gen head units use cvbs also.
          Rcd330, composition media or Discover Media
          Sent from my SM-G960F using Tapatalk
