The purpose of this topic is to share the experience of those who own an RNS510 with integrated DAB Tuner.
Currently I have received a radio card with built-in TNT tuner and the associated motherboard. I installed them in the RNS510 in replacement.
I do not see the DAB option next to FM and AM in the "band" window.
So I try to update the firmware for it to appear. I note that the DAB tuner is currently not connected to an antenna.
The only firmware I can install is the 6276 that can be found on mygti.com
I tried almost all the other precedents, none works.
At the very beginning of the update procedure the screen attached (sorry for the wrong orientation) to this message indicates some information. In particular the list of models concerned by this firmware.
Out, we only see models in xxxx680.
<img src="https://www.vwwatercooled.com/forums/attachments/f78/47285-rsn510-built-dab-tuner-firmware-install-6276-a-dab-jpg" attachmentid="47285" alt="" id="vbattach_47285" class="previewthumb">
Models in 680 are not normally equipped with an integrated DAB tuner.
Models with this card have a number in xxx686 [letter]. The 68x corresponding to a material intended for Europe.
During the installation process, the DAB part appears as "to be updated, just after the GATEWAY.
But once the GATEWAY update, the RNS510 reboot and the DAB part is not processed.
It is noticeable when one does not see "DAB" in the window "BAND".
The conclusion would be that the firmware 6276 that I am trying to install is not made for the RNS510 with built-in DAB tuner.
Is it correct ? If so, where can you download a firmware that recognizes the built-in DAB tuner?
If no: what are we intended to do for in order that the firmware well recognized the DAB card inside the RNS510 before starting its process?
An action with VCDS?
In the installation list of GATEWAY in VCDS, we see "Digital Radio". Should we activate it? Should an option be modified in the "Navigation" module or elsewhere?
Thanks for your help.
