My situation is that we have a MY12 Mk6 Golf R w/RCD510 and factory dynaudio amp/speakers, factory bluetooth and an ipod connector. I've owned it since new, so 7 years or so now.
We also have a MY18 Passat - speakers are nearly as good, and the head unit is so much more usable (and further integrated into the car itself - I don't imagine it would be simple to ever upgrade the head unit here!). Using apple carplay is so much on the newer passat than the golf - especially now that we can use the phone's map apps (Waze!)
I like the speakers and amp in the golf, but i've always hated the head unit. it's slow and fiddly to use - if you're in the mood for a specific album, for example, it will take 2-4 minutes of fiddling with the scroll bars if you have a lot of music on the SD card or ipod or whatever.
I have tried to do some research but have questions that I hope the forum can help with
1. If we uprade the head unit, what do I need to do to maintain a connection to the dynaudio amp/speakers - if the new head unit has pre-outs, can I assume these will be compatible (I see some sites offering kits)
2. Can/should aftermarket head units use the factory bluetooth microphone?
3. I did consider the RCD330 - but I seem to read a lot mostly negative experiences when using a dynaudio amp - this seems like it would be a good solution except for this
4. do I need to do any coding or anything if the head unit disappears?
5. do we lose any functionality if we get an aftermarket As far as I know, the head unit displays air-con status changes, but otherwise doesn't really 'do' anything in terms of car settings (vs the passat, where most things are done using the 'head unit's screen)
