I came across this while mucking around with VCDS yesterday, and have since found it documented elsewhere so thought I'd share.
For those with memory seats, you can enable a function called 'easy access'. When you pull the keys out of the ignition, the seat will move back away from the steering wheel a little, (not as much as I was hoping, but its something) allowing you to get out more easily. Then when you get back in and start the car, it moves back to your saved position.
easy entry/exit memory seat function -mk5 VW | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
